Solving Confusion About Black Holes, Schwarzschild Radius & Time Dilation
In summary, according to the theory of black holes, any mass has a Schwarzschild radius and objects smaller than their Schwarzschild radius are classified as black holes. Mini black holes can be created and have the same ability to curve space-time as regular black holes. The smaller the black hole, the larger the curvature at its event horizon. However, objects like protons are significantly larger than black holes of the same mass and have a very small effect on space-time curvature. When an object crosses the event horizon of a super massive black hole, it appears frozen from an observer's perspective. There is no gravitational pull in general relativity, but there is a force required to hover outside the event horizon that increases infinitely as you approach it.
arkantos
According to the theory, every mass has a Schwarzschild radius associated. Any object whose radius is smaller than its Schwarzschild radius is called a black hole.
So in principle is possible to create mini-black holes, it is just a fact of matter condensed.
Those mini black holes have their event horizon ecc, and despite their should evaporate in a infinitesimal amount of time, they have the same capacity to curve space time in the same fashion regular black holes do.
But I guess there is something wrong with my understanding of the theory, because:
Space time curvature is progressive for astronomical objects, for example Neutron Stars curve space-time 'more deeply' as they get closer the their Schwarzschild radius, and eventually becoming black holes.
Now, according to this logic, the more an object get closer to its SH radius, the more it curves space-time. Is this statement applicable to objects on the Earth? Ab absurdum, does an atomic nucleo curve space time more than a big and heavy rock?
The curvature at the event horizon is actually inversely proportional to the mass - the smaller the BH, the larger the curvature at its event horizon. On the other hand, a proton, for example, is actually almost 40 orders of magnitude larger in radius than a BH of the same mass, so it is 'enormously further from being a BH' than is the earth. Thus the curvature it produces is wholly insignificant.
okay, thanks for the answer.
So now I have another question: from the point of view of an observer, when an object crosses the event horizon of a super massive black hole, which density is low,it will be frozen immediately right?
According to the observer the object is already frozen in time even if the curvature at the event horizon, and so the gravitational pull, it's not extreme, right?
An observer outside the EH never receives a light signal from an object crossing the horizon.
There is, strictly speaking, no gravitational "pull" in GR. There is, however, a force required to hover outside the EH. That force increases without limit as you approach the EH.
FAQ: Solving Confusion About Black Holes, Schwarzschild Radius & Time Dilation
What is a black hole?
A black hole is a region in space where the gravitational pull is so strong that nothing, including light, can escape. This happens when a massive star dies and its core collapses under its own gravity.
What is the Schwarzschild radius?
The Schwarzschild radius is the distance from the center of a black hole where the escape velocity is equal to the speed of light. It is the point of no return, also known as the event horizon.
How does time dilation occur near a black hole?
Time dilation occurs near a black hole because of the extreme gravitational pull. This causes time to slow down for an observer outside the black hole, while time appears to pass normally for an observer falling into the black hole.
Can anything escape a black hole?
No, once something passes the event horizon of a black hole, it cannot escape. The gravitational pull is too strong for anything, including light, to escape.
Can black holes merge?
Yes, black holes can merge if they are close enough in proximity. This usually happens when two galaxies collide, causing their respective black holes to merge into a larger one.
