Solving derivative of exponential function
In summary, the conversation discusses finding the intervals of increase and decrease, local maximum and minimum values, and concavity and inflection points of a function f(x) = xex. The solution involves finding the critical numbers by setting f'(x) = 0 and solving for x, which leads to the conclusion that the only critical number is x = -1.
synergix
178
-Find the intervals on which f is increasing or decreasing
-Find the local maximum and minimum values of f
-Find the intervals of concavity and the inflection points
f(x)=xex
f'(x)= ex+xex
then I must solve for x when the function equals zero to find my critical numbers
2x+ln(x)=0
The problem is I don't know how to get rid of the ln() to solve for x. Not that it would help all my terms have x's. so how would I find the critical number of this function? or is their only one, zero? zero because ln()is undefined at zero
synergix said:
2x+ln(x)=0
This tells you where the logarithm of the derivative is zero, which is not what you were asked for. Instead try
[tex] f'(x) = (1+x)e^x = 0 [/tex] if [tex] e^x = 0 [/tex] or ...
x1=-1
If I try and solve e^x for zero i get x DNE so how do I find out where the critical point is?
or is -1 the only critical number?
Yes, x = -1 is the only critical point since ex is never 0.
thank you
FAQ: Solving derivative of exponential function
1. What is the formula for finding the derivative of an exponential function?
The formula for finding the derivative of an exponential function is y = ab^x, where a is the base and b is the power.
2. How do you solve for the derivative of an exponential function?
To solve for the derivative of an exponential function, you can use the power rule of differentiation. This involves taking the derivative of the base, multiplying it by the original function, and then raising the base to one less than the original power.
3. What is the purpose of finding the derivative of an exponential function?
The purpose of finding the derivative of an exponential function is to determine the rate of change of the function at any given point. This can be useful in various fields such as physics, economics, and engineering.
4. What are the common mistakes to avoid when solving for the derivative of an exponential function?
One common mistake when solving for the derivative of an exponential function is forgetting to use the power rule and instead using the product rule. It is also important to remember to multiply the derivative of the base by the natural log of the base when using the power rule.
5. Can you provide an example of solving for the derivative of an exponential function?
Yes, for example, if we have the function y = 5(2^x), the derivative would be y' = ln(2) * 5(2^x). This can be simplified to y' = 5ln(2)(2^x).
