I Solving Differential Equation Using Reduction of Order
  • I
  • Thread starter Thread starter giodude
giodude
Hello,
I'm working on the following differential equation:In problem 23 through 30 use the method of reduction of order to find a second solution of the given differential equation.
27. xy'' - y' + 4*x^3*y = 0, x > 0; y_1(x) = sin(x^2)
I begin my solution by writing out the known equations of y, y', y'' in terms of v and y_1. I also differentiate y_1 to find y_1', y_1'':
Let v denote v(x):
y = v*y_1
y' = v'*y_1 + v*y_1'
y'' = v''*y_1 + 2v'y_1' + v*y_1''
y_1 = sin(x^2) (given)
y_1' = 2*x*cos(x^2)
y_1'' = 2*cos(x^2) - 4*x^2*sin(x^2)
Next, I plug y, y', and y'' into the original differential:
x*(v''*y_1 + 2*v'*y_1' + v*y_1'') - v'*y_1 - v*y_1' + 4*x^3*v*y_1 = 0
x*v''*y_1 + (2*x*y_1' - y_1)*v' + (xy'' - y' + 4*x^3*y)v = 0 (the coefficient of v is our original differential so we may set that to 0)
x*v''*y_1 + (2*x*y_1' - y_1)*v' = 0
v'' + (2*x*y_1' - y_1) / (x*y_1)*v' = 0
Now we need to solve this first order differential equation (I use integration factors to solve):
d[mu]/dx = (2*x^2*cos(x^2)/xsin(x^2) - sin(x^2)/(x*sin(x^2))) * mu
d[mu]/dx = (2*x*cot(x^2) - 1/x)*mu
(1/mu)*d[mu]/dx = 2*x*cot(x^2) - 1/x
Differentiating both sides:
ln(mu) = -ln(sin(x^2)) - ln(x)
Exponentiating both sides:
mu = 1/(x*sin(x^2))
Plugging the integrating factor back in we get:
d[(1/(x*sin(x^2))) * v']/dx = 0
1/(x*sin(x^2)) * v' = C_1
v' = C_1*x*sin(x^2)
Integrating v':
v = -C_1*(1/2)*cos(x^2) + C_2
We can collapse -C_1*(1/2) into a C_1 to represent that entire constant term. Solving for y by computing v*y_1:
y = C_1*cos(x^2)*sin(x^2) + C_2*sin(x^2)
The answer in the textbook I'm using says that y_2 = cos(x^2), however this indicates a solution of y_2 = cos(x^2)*sin(x^2). Is this an interpretation problem such that this answer does in fact suggest y_2 = cos(x^2) or did I go wrong somewhere within my process of solving?
Thank you!
I don't agree with your result for v.
Your equation for v&#039; can be reduced to <br /> \begin{split}<br /> 0 &amp;= xy_1v&#039;&#039; + (2xy_1&#039; - y_1)v&#039; \\<br /> &amp;= \frac{x^2}{y_1} \left( \frac{y_1^2}x v&#039;&#039; + \left( \frac{2y_1y_1&#039;}{x} - \frac{y_1^2}{x^2}\right)v&#039;\right) \\<br /> &amp;= \frac{x^2}{y_1} \frac{d}{dx}\left( \frac{y_1^2 v&#039;}{x}\right) \end{split} from which it follows that v&#039; = \frac{Cx}{y_1^2} = \frac{Cx}{\sin^2(x^2)}. Comparing this to your working suggests that something has gone wrong in your application of the integrating factor method, so I would suggest you try that again.
My equation for v&#039; can be integrated by substitution, leading to the book's answer.
Oh, found my two mistakes:
(1) I dropped the two when integrating 2*x*cot(x^2).
(2) I added a negative (mixed up with tan(x^2)) when integrating cot(x^2).
Fixing these two leads to the proper answer. Thank you!
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
