Solving Elasticity & Work Problems
In summary, the work done in stretching a wire must be W = [YA(∆L)^2] / 2L, where ∆L is the amount of stretch, Y is the Young's modulus, and A is the cross sectional area of the wire. This can be derived by considering the relationship between the displacement (∆L) and the applied force (F), and using the definition of work done by a force.
ppkjref
A wire of length L, Young's modulus Y, and cross sectional area A, is stretch elastically by an amount ∆L.
show that the work done in stretching a wire must be W = [YA(∆L)^2] / 2L
∆L = (1/Y)(F/A)L
W = F * d (where displacement = ∆L)
If ∆L = (1/Y)(F/A)L
F = (YA∆L)/L
Also if W = F * d (where displacement = ∆L)
W = F * ∆L
F = W/∆L
Then, (YA∆L)/L = W/∆L
[YA(∆L)^2] / L = W
However I do not see how W = [YA(∆L)^2] / 2L. I am missing the 2.
∆L = (1/Y)(F/A)L
If ∆L = (1/Y)(F/A)L
F = (YA∆L)/L
W = F * ∆L
F = W/∆L
[YA(∆L)^2] / L = W
That's because the applied force is not constant, it varies linearly from 0 at the start to a max value at (∆L), similar to a force in a spring which varies in the same manner (F=kx, Hooke's law). You can find the work done by using calculus and the definition of work done by a force, or since the force varies linearly with x, you can just take the average of the max and min force values.
Okay thanks for your help.
FAQ: Solving Elasticity & Work Problems
What is the definition of elasticity?
Elasticity refers to the ability of a material to deform and then return to its original shape and size when the force or stress applied to it is removed.
How is elasticity measured?
Elasticity is typically measured by the ratio of the change in length or volume of a material to the original length or volume, known as the strain, divided by the amount of stress applied, known as the modulus of elasticity.
How does elasticity relate to work?
In physics, work is defined as the product of force and displacement. In the context of elasticity, work is done when a force is applied to a material and it deforms, expending energy to change its shape. When the force is removed and the material returns to its original shape, the energy is released, resulting in a net work of zero.
How do I solve elasticity and work problems?
To solve elasticity and work problems, you need to identify the given values for force, displacement, and modulus of elasticity, and then use the appropriate formula to calculate the desired variable. It's important to pay attention to units and use consistent units throughout the calculation.
What are some real-world applications of elasticity and work?
Elasticity and work are important concepts in many fields such as engineering, construction, and materials science. Some examples of real-world applications include designing springs for cars, calculating the force needed to bend a metal beam, and understanding the behavior of rubber in everyday objects like tires and rubber bands.
