Solving energy-momentum equations for lamba decay
The discussion focuses on solving energy-momentum equations related to the decay of a lambda particle into a proton and a pion. The rest masses of the lambda, proton, and pion are provided, and the goal is to determine the energy of the pion and the lambda before decay. The energy-momentum 4-vector equation is identified as crucial for the calculations, emphasizing the need to conserve both energy and momentum. The initial approach involved calculating the pion's energy based on mass deficit and rest mass, while also considering the lambda's momentum. Ultimately, the use of 4-momentum equations clarified the solution process.
jturko
A lambda particle decays into a proton (at rest) and a pion. The rest masses are:
lambda: 1116 MeV/c^2
pion: 140 MeV/c^2
proton: 938 MeV/c^2
we want to find the energy of the
a) pion
b) lambda (before decay)
I am assuming we need to use the energy-momentum 4-vector equation
E2=(mc2)2 + (pc)2
So I think we know in the lab frame that the momentum of the pion and the lambda are the same, since the proton is at rest. So the energy of the pion must be its rest mass plus the mass deficit from the lambda; 140+(1116-(140+938))=140+38=178 , but there must be some energy that is from the initial momentum of the lambda. Could there be a missing parameter? I am unsure how you would figure out how much energy would be from the momentum without any other information.
You must also conserve momentum, write a 4-vector eqn 4-momentum in = 4-momentum out. That will also handle energy conservation.
Awesome! thank you, I was just regrouping my terms sloppily. Once looking at the 4 momenta it became clear very quickly!
  • · Replies 33 ·
  • · Replies 34 ·
