MHB Solving Enthalpy Questions: Calculating Heat Change in a Coffee-Cup Calorimeter
  • Thread starter Thread starter eleventhxhour
To solve the enthalpy change for the reaction between NaOH and H2SO4 in a coffee-cup calorimeter, first convert the reactants into moles, yielding 0.1025 mol NaOH and 0.06 mol H2SO4. The standard enthalpy of formation for NaOH is -470.1 kJ/mol, which indicates energy is released during the reaction. Calculate the energy released using the formula q = n·Δ_f H^0 for both reactants and products. The difference in energy will provide the total heat change, which can then be used to find the temperature increase in the calorimeter. Understanding these steps is crucial for accurately determining the enthalpy change.
eleventhxhour
So I have two more enthalpy questions that I don't understand how to solve.
1) A student placed 50.0mL of 2.05mol/L NaOH in a coffee-cup calorimeter at 20.4°C. After quickly stirring the mixture, its temperature rose to 28.2°C. Determine the enthalpy change for the reaction:
2NaOH(aq) + H2SO4(aq) --> 2H2O(l) + Na2SO4(aq)
I tried converting NaOH and H2SO4 into grams, and then finding the q=mcdeltaT of it, but you don't have the c of the values so I couldn't do that.
Mathematics news on Phys.org
Hi eleventhxhour,
You need the enthalpy of each of those compounds.
You should have a table available in which you can find them.
For instance this table on wiki tells us that NaOH(aq) has a standard enthalpy change of formation of:
$$Δ_f H^0 = -470.1\text{ kJ/mol}$$
Since the unit is in kJ/mol, you will need the number of moles of each compound instead of the grams.
I like Serena said:
Hi eleventhxhour,
$$Δ_f H^o = -470.1\text{ kJ/mol}$$
So I converted each compound into moles and got 0.1025mol NaOH and 0.06molH2SO4. But I'm not sure what to do next. Would you use the equation q=mcdeltaT and find the total q for the reaction? And then use the equation deltaH=ndeltaHx? When I do this, I get the wrong answer...
Good!
You are too early with your formula.
First you need to find the energy released by the reaction.
The standard enthalpy of formation is the amount of energy it takes to bind the atoms of 1 mole of the compound.
If you want a formula, it's:
$$q = n\cdot \Delta_f H^0$$
Note that this number is negative for $\ce{NaOH(aq)}$.
That should be expected, since energy would be released when in particular the O and H are bound together.
It means you can calculate the amount of energy it takes to form the compounds on the left hand side of the reaction.
And you can also calculate the amount of energy it takes to form the compounds on the right hand side.
The difference is the amount of energy that is released a part of the reaction.When you have that energy, you can apply your formula to calculate the temperature increase of the water.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
