Solving Entropy in Moist Air: No Violation of Law
In summary, when the air outside is cold and dry, the climate control system must humidify the air to prevent singers from losing their voices. This process involves evaporating pure water into the dry air, which lowers the temperature of the air due to the use of thermal energy. However, this does not violate the law of entropy because slight reductions in temperature only result in slight decreases in entropy and are statistically likely to occur. Additionally, mixing water and air causes disorder and an increase in entropy, which also does not violate the law of entropy.
Dreebs
25
When the air outside is very cold and dry, your climate control system must humidify the cabaret air so that the singers don't lose their voices. The climate control let's pure water evaporate into the dry air and raises the moisture content of that air. As this evaporation occurs, the temperature of the air drops somewhat because thermal energy is used to turn the liquid water into water vapor. But lowering the temperature of something usually means lowering its entropy! Why doesn't this process of mixing water and air to create slightly colder, moister air violate the law of entropy?
Select one:
a. As the air cools by evaporation, heat flows naturally from the warmer dry air to the cooler moist air. The presence of natural heat flow ensures that the law of entropy is not violated.
b. Even though the moist air is cooler than the separated water and dry air, the moist air contains more thermal energy.
c. Slight reductions in temperature produce only slight decreases in entropy. They are therefore statistically likely to occur and do not violate the law of entropy.
d. Mixing the two chemicals (water and air) produces a large amount of disorder, so that the total entropy of the system does not decrease.
C. [/B]Because slight reductions in entropy are still allowed without violating the law of entropy.
Select one:
Such reductions would be random, and if of any magnitude then very rare. That does not cover the process here.
That makes sense. So in D, does mixing the two chemicals cause entropy to increase? I think it does but I'm not entirely sure.
Related to Solving Entropy in Moist Air: No Violation of Law
What is entropy in moist air?
Entropy in moist air refers to the measure of the disorder or randomness in the air due to the presence of water vapor. It is a thermodynamic property that affects the behavior of moist air and is important in understanding various atmospheric processes.
Why is it important to solve entropy in moist air?
Solving entropy in moist air is important because it helps us understand the behavior of the atmosphere and its impact on various natural phenomena such as weather patterns, cloud formation, and climate change. It also allows us to develop more accurate models and predictions for atmospheric processes.
What is the law of conservation of energy and how does it relate to solving entropy in moist air?
The law of conservation of energy states that energy cannot be created or destroyed, only transformed from one form to another. This law applies to all thermodynamic processes, including the behavior of moist air. Solving entropy in moist air ensures that this law is not violated and allows us to accurately calculate the energy changes in the air due to the presence of water vapor.
How is entropy calculated in moist air?
Entropy in moist air is calculated using the Clausius-Clapeyron equation, which takes into account the temperature, pressure, and specific humidity of the air. This equation allows us to determine the change in entropy as water vapor is added or removed from the air.
What are some potential applications of solving entropy in moist air?
Solving entropy in moist air has many practical applications, including weather forecasting, climate modeling, and air conditioning and refrigeration systems. It also plays a crucial role in understanding and predicting the behavior of clouds and precipitation, as well as air pollution and air quality.
  • Classical Physics
9K
