Solving Equation: (1/x)^x - x = 0
  • Thread starter EL ALEM
In summary, the equation (1/x)^x - x = 0 can be rewritten as xln(1/x) = lnx, which has no elementary solution but can be solved using Lambert's W function. The solutions x=1 and x=-1 can also be obtained algebraically, but they are not considered elementary solutions.
EL ALEM
(1/x)^x - x = 0
(1/x)^x - x = 0
(1/x)^x = x
xln(1/x) = lnx
Thats all i got up to, I just need a kick in the right direction so I can finish it up.
EL ALEM said:
(1/x)^x - x = 0
(1/x)^x - x = 0
(1/x)^x = x
xln(1/x) = lnx
How is ln(1/x) related to ln(x)? HINT: Have a look at the properties of logarithms
[tex]\frac{1}{x^{x}} - x = 0[/tex]
becomes
[tex]\frac{1}{x^{x}} = x[/tex]
becomes[tex] 1= x^{x+1}[/tex]
becomes
[tex] \ln 1= \ln x^{x+1}[/tex]
becomes
[tex] 0 = (x+1)\ln x [/tex]
Of course, that has no "elementary" solution. It probably can be solved in terms of Lambert's W function.
What about x=1 or x=-1? Are they not considered elementary solutions; they can be obtained without the use of any non-elementary function?
(1/x)^x-x=0
(1/x)^x=x
xln(1/x)=lnx
lnx=xln(1/x)
lnx=x(ln1-lnx)
lnx=x(0-lnx)
lnx=-xlnx
x=-1
DCASH88 said:
(1/x)^x-x=0
(1/x)^x=x
xln(1/x)=lnx
lnx=xln(1/x)
lnx=x(ln1-lnx)
lnx=x(0-lnx)
lnx=-xlnx
x=-1
In the last step you divided both sides by ln(x) which implicitly assumed that ln(x) is not equal to zero i.e. x is not equal to 1. It turns out that x=1 also solves the equation.
DCASH88 said:
(1/x)^x-x=0
(1/x)^x=x
xln(1/x)=lnx
lnx=xln(1/x)
lnx=x(ln1-lnx)
lnx=x(0-lnx)
lnx=-xlnx
x=-1
Please do not do the OP's homework for him. It is against the PF rules (see the link at the top of the page) to provide solutions to homework here. Please confine your help to giving hints, asking questions, finding errors in their work, etc.
Yes I noticed that just by looking but didn't know how to show. Will you show how to come to that?
Thanks
Daniel
If you're referring to danago's response, then it's just like solving a quadratic.
When you have [tex]x^2=x[/tex] you don't divide through by x to leave x=1, because that implies [tex]x\neq 0[/tex], but it is a solution. All you do instead is factorize to leave [tex]x(x-1)=0[/tex] which now gives the solutions x=0,1. Do the same for your equality.
FAQ: Solving Equation: (1/x)^x - x = 0
What is the equation (1/x)^x - x = 0 used for?
The equation (1/x)^x - x = 0 is commonly used in mathematics and science to solve for the value of x in exponential equations. It is also useful in finding the root or intersection point of a curve.
How do you solve the equation (1/x)^x - x = 0?
To solve this equation, you can use algebraic manipulation and the properties of logarithms. First, rewrite the equation as (1/x)^x = x. Then, take the logarithm of both sides using the property log(a^b) = b*log(a), giving us x*log(1/x) = log(x). Simplify the left side to log(1/x^x) = log(x), and then use the property log(a^b) = b*log(a) again on the left side, giving us x*log(1/x) = x*log(x). Finally, solve for x by dividing both sides by log(1/x), giving us x = 1/log(1/x).
Are there any restrictions on the values of x that can be used in this equation?
Yes, there are restrictions on the values of x that can be used in this equation. Since we cannot take the logarithm of a negative number, x must be greater than 0. Additionally, x cannot equal 1, as this would result in division by 0.
Can this equation be solved using a calculator?
Yes, this equation can be solved using a calculator. You can use the logarithm function on your calculator to find the value of log(1/x), and then use that value to solve for x as shown in the previous question.
How is this equation relevant in real-world applications?
The equation (1/x)^x - x = 0 has various real-world applications in fields such as biology, chemistry, and physics. For example, it can be used to model population growth, chemical reactions, and radioactive decay. It is also used in finance and economics to calculate compound interest and inflation rates.
