MHB Solving Equation 4: Progress & Questions
  • Thread starter Thread starter Petrus
The discussion revolves around solving the equation 4cos²(x) - 4 = 6cos(x) by substituting u = cos(x), leading to the quadratic equation 4u² - 6u - 4 = 0. The solutions for u are u₁ = -1/2 and u₂ = 2, with the first solution yielding x = 3π/2 + 2kπ. There is confusion regarding the second solution, x = -3π/2 + 2kπ, and the implications of the inverse cosine function. Participants emphasize the importance of understanding the multivalued nature of the cosine function and suggest graphing the equation to ensure all solutions are identified.
Petrus
Hello MHB,
This is an old exam.What real x satisfies equation $$4\cos^2(x)-4=6\cos(x)$$
Progress:
Subsitute $$u=\cos(x)$$ and I solve this equation
$$4u^2-6u-4=0 $$
$$u_1=-\frac{1}{2}$$ and $$u_2=2$$
so if we take arccos of them we get
$$x=\frac{3\pi}{2}+2k\pi$$ which agree with facit but they got also $$x=-\frac{3\pi}{2}+2k\pi$$ which I don't understand also how shall I know what $$x=\cos^{-1}(2)$$ is in exam? I am doing something wrong or..?
Regards,
$$|\pi\rangle$$
Mathematics news on Phys.org
Re: cos equation
Well, $\cos{(x)} = \cos{(x + 2 \pi)}$ by definition ($2 \pi$ is like adding one whole revolution to your angle, so it's the same angle). The inverse cosine function is multivalued, but $\arccos$ is defined as the principal value. Then $\cos{(x)} = \cos{(-x)}$ and so that second value follows (can you see why?)
You need to be careful here because manipulating such multivalued functions can create or destroy solutions to your original equation, so always graph your equation to get a rough idea where the roots are to be sure you didn't miss any and so on.
EDIT: inb4 reply tsunami (Tongueout)
Re: cos equation
I think you mean to write one of the solutions is:
$$x=\frac{2\pi}{3}+2k\pi$$ where $$k\in\mathbb{Z}$$
and since $\cos(-\theta)=\cos(\theta)$, we also have:
$$x=-\frac{2\pi}{3}+2k\pi$$
which means we may write:
$$x=\frac{2\pi}{3}(6k\pm1)$$
Re: cos equation
Hello MHB,Thanks for fast responed and help! I will have to check this more :) I have indeed seen that $$\cos(x)=\cos(-x)$$ but I don't think I know why but I will think about this and how does it work with sinus?
Regards,
$$|\pi\rangle$$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
