Solving equation with two different variables
  • Thread starter gnome222
  • Tags
    Variables
In summary, there are two solutions for x for each given n, and they are determined by a quadratic equation involving the factorials of n and (n/2) and (n-2)/2.
gnome222
(n-1)! = (x2 + x)( (n/2)! (n-2/2)!
Any idea how to solve this? I tried to solve for x but got stuck. Could you multiply out the factorials?
Mathematics news on Phys.org
What exactly are you trying to do?
If this is what you wrote:
[tex](n-1)!=\left(x^2+x\right)\left(\frac{n}{2}\right)!\left(\frac{n-2}{2}\right)![/tex]
Then x can be many values, for example, if we take n=2 then
[tex](2-1)!=(x^2+x)\times1!\times0![/tex]
[tex]x^2+x=1[/tex]
For n=4:
[tex](4-1)!=(x^2+x)\times 2!\times1![/tex]
[tex]x^2+x=3[/tex]
So as you can see, x can take on various values depending on n, and vice versa. If you could show that
[tex]\frac{(n-1)!}{\left(\frac{n}{2}\right)!\left(\frac{n-2}{2}\right)!}[/tex]
was a constant (which it isn't) then x would have an explicit solution (likely two solutions since it's a quadratic).
If I have not screwed something up (and since I am recovering from knee surgery and have some pain meds in me, I might have) you can write
[tex]x=-\frac{\sqrt{{\left( \frac{n-2}{2}\right) !}^{2}\,{\left( \frac{n}{2}\right) !}^{2}+4\,\left( \frac{n-2}{2}\right) !\,\left( n-1\right) !\,\left( \frac{n}{2}\right) !}+\left( \frac{n-2}{2}\right) !\,\left( \frac{n}{2}\right) !}{2\,\left( \frac{n-2}{2}\right) !\,\left( \frac{n}{2}\right) !}[/tex]
or
[tex]x=\frac{\sqrt{{\left( \frac{n-2}{2}\right) !}^{2}\,{\left( \frac{n}{2}\right) !}^{2}+4\,\left( \frac{n-2}{2}\right) !\,\left( n-1\right) !\,\left( \frac{n}{2}\right) !}-\left( \frac{n-2}{2}\right) !\,\left( \frac{n}{2}\right) !}{2\,\left( \frac{n-2}{2}\right) !\,\left( \frac{n}{2}\right) !}[/tex]
Since x is a solution to a quadratic, there are 2 solutions for each n. Take both square roots to get them.
Both solutions are in my post.
FAQ: Solving equation with two different variables
What is the purpose of solving equations with two different variables?
Solving equations with two different variables allows us to find the relationship between two quantities and determine the value of each variable. This is useful in many real-world situations, such as calculating distances or determining the cost of multiple items.
Can equations with two different variables have more than one solution?
Yes, equations with two different variables can have an infinite number of solutions. This means that there are multiple combinations of values for the variables that satisfy the equation. It is important to carefully check the solutions to ensure they are valid.
How do I solve an equation with two different variables?
To solve an equation with two different variables, we need to isolate one variable on one side of the equation and then substitute its value into the other side. This will give us an equation with only one variable, which we can then solve using algebraic techniques.
What should I do if I get a contradictory solution when solving an equation with two different variables?
A contradictory solution means that the equation has no solution, and the values for the variables cannot satisfy the equation. This can happen if we make a mistake when solving the equation or if the original equation is not valid for the given variables. In this case, we should recheck our steps and make sure the equation is set up correctly.
Are there any shortcuts for solving equations with two different variables?
Yes, there are some shortcuts that can be used to solve specific types of equations with two different variables. For example, the substitution method can be used when one variable is already isolated in one of the equations, and the elimination method can be used when both equations have the same coefficient for one of the variables. However, it is important to understand the underlying principles of solving equations to effectively use these shortcuts.
