Solving Even Function Integrals: $a_0$ & $a_n$
In summary: If you don't believe me, you can double-check using the substitutions $u = \cos\theta$ and $du = -\sin\theta\, d\theta.$Kind Regards,Sudharaka.In summary, the given function $f(-\theta) = |\sin(-\theta)| = |-\sin\theta| = |\sin\theta| = f(\theta)$ is even and can be represented by the Fourier series $f(\theta) = \frac{a_0}{2} + \sum_{n=1}^{\infty}a_n\cos n\theta$, where $a_0 = \frac{2}{\pi}\int_{0}^{\pi
Dustinsfl
2,281
$f(-\theta) = |\sin(-\theta)| = |-\sin\theta| = |\sin\theta| = f(\theta)$.
Hence, $f$ is even, and we need to only consider.
f(\theta) = \frac{a_0}{2} + \sum_{n = 1}^{\infty}a_n\cos n\theta.
a_0 = \frac{1}{\pi}\int_{-\pi}^{\pi}|\sin\theta|d\theta = \frac{1}{\pi}\int_{0}^{\pi}\sin\theta d\theta - \frac{1}{\pi}\int_{-\pi}^0\sin\theta d\theta = \frac{2}{\pi}\int_{0}^{\pi}\sin\theta d\theta
but when I solve this integral, I get 0.
How do I solve this integral?
a_n =\frac{1}{\pi}\int_{-\pi}^{\pi}|\sin\theta|\cos n\theta d\theta = \frac{2}{\pi}\int_{-\pi}^{\pi}\sin\theta\cos n\theta d\theta
Hi dwsmith, :)
\[\int_{0}^{\pi}\sin\theta d\theta=\left. -\cos\theta\right|^{\pi}_{0}=-\cos\pi+\cos 0=1+1=2\]
\begin{eqnarray}
\int_{-\pi}^{\pi}|\sin\theta|\cos n\theta d\theta&=&-\int_{-\pi}^{0}\sin\theta\cos n\theta d\theta+\int_{0}^{\pi}\sin\theta\cos n\theta d\theta\\
&=&\int_{0}^{\pi}\sin\theta\cos (n\pi-n\theta) d\theta+\int_{0}^{\pi}\sin\theta\cos n\theta d\theta\\
&=&(-1)^{n}\int_{0}^{\pi}\sin\theta\cos n\theta d\theta+\int_{0}^{\pi}\sin\theta\cos n\theta d\theta\\
\end{eqnarray}
\[\therefore a_{2n}=\frac{2}{\pi}\int_{0}^{\pi}\sin\theta\cos 2n\theta d\theta\mbox{ and }a_{2n+1}=0\mbox{ where }n\geq 1\]
Use integration by parts to evaluate this integral. Solution can be found >>here<<.
Kind Regards,
Sudharaka.
Sudharaka said:
\int_{0}^{\pi}\sin\theta\cos (n\pi+n\theta) d\theta+\int_{0}^{\pi}\sin\theta\cos n\theta d\theta
Why do you have this instead of
2\int_{0}^{\pi}\sin\theta\cos n\theta d\theta
$\displaystyle \int_{0}^{\pi}\sin\theta\, d\theta = 2$, so you should get $a_0 = 4/\pi.$
a_n =\frac{1}{\pi}\int_{-\pi}^{\pi}|\sin\theta|\cos n\theta d\theta = \frac{2}{\pi}\int_{\color{red}0}^{\pi}\sin\theta \cos n\theta d\theta
Integrate by parts twice, to get $$\int_{0}^{\pi}\sin\theta\cos n\theta\, d\theta = \begin{cases}\frac{-2}{n^2-1} & (n \text{ even}), \\ 0 & (n \text{ odd}). \end{cases}$$
Both answers are fine, I didn't realize that first and made a confusion by thinking your answer is wrong. Opalg's post seem to answer your question directly.
Kind Regards,
Sudharaka.
The Fourier series is
\frac{2}{\pi} - 2\sum_{n = 1}^{\infty}\frac{1}{4n^2 - 1}\cos 2n\theta.
Getting there! But you have still forgotten to multiply the integral by $2/\pi$ to get $a_n.$ The answer should be $$\frac{2}{\pi} - \frac4\pi\sum_{n = 1}^{\infty}\frac{1}{4n^2 - 1}\cos 2n\theta.$$
I had
\frac{-2}{n\pi}\left[\left.\frac{\cos\theta\cos n\theta}{n}\right|_0^{\pi} - \frac{1}{n}\int_0^{\pi}\cos n\theta\sin\theta d\theta\right] = \frac{2}{\pi}\int_0^{\pi}\cos n\theta\sin\theta d\theta
The $2/\pi$ canceled.
Huh? What did it cancel with? I can guarantee that the answer I gave in my previous comment is correct.
FAQ: Solving Even Function Integrals: $a_0$ & $a_n$
What is an even function integral?
An even function integral is an integral where the function being integrated is symmetric about the y-axis. This means that if you were to fold the graph of the function along the y-axis, the two halves would overlap perfectly. Examples of even functions include cos(x), x^2, and |x|.
What is the significance of $a_0$ and $a_n$ in solving even function integrals?
In solving even function integrals, $a_0$ represents the constant term in the Fourier series expansion of the function, while $a_n$ represents the coefficient of the cosine term. These values are important because they allow us to express the even function as a sum of cosine functions, making it easier to integrate.
How do you find the value of $a_0$ and $a_n$ in even function integrals?
To find the value of $a_0$, you can use the formula a_0 = 1/π ∫f(x)dx, where f(x) is the even function being integrated. To find the value of $a_n$, you can use the formula a_n = 1/π ∫f(x)cos(nx)dx. These integrals can be evaluated using integration by parts or other integration techniques.
Can you use $a_0$ and $a_n$ to solve any even function integral?
Yes, $a_0$ and $a_n$ can be used to solve any even function integral. However, in some cases, it may be more efficient to use other integration techniques such as substitution or trigonometric identities.
Are there any limitations to using $a_0$ and $a_n$ in solving even function integrals?
One limitation of using $a_0$ and $a_n$ is that they can only be used for even functions. This means that if the function being integrated is not symmetric about the y-axis, these techniques cannot be applied. Additionally, the Fourier series representation may not converge for some functions, making it difficult to find the values of $a_0$ and $a_n$.
