Solving expansion rate for a variant of the Friedmann equation
In summary, the equation H^2 = \frac{8 \pi G \rho_m}{3} + \frac{H}{r_c} shows that H acts as though dominated by the cosmological constant, as the scale factor approaches infinity. This is because, when the matter density is replaced by the scale factor and taken to infinity, the equation reduces to H = \frac{1}{r_c}, showing that H is solely dependent on the constant r_c. When solving for the scale factor, it is found to be a = \exp(\frac{t}{r_c}), which is similar to the equation for dark energy domination, a \propto \exp(Hr_c). Therefore, H behaves as if it is
Kyrios
28
For the equation [tex] H^2 = \frac{8 \pi G \rho_m}{3} + \frac{H}{r_c} [/tex] how do I find the value of H for scale factor [itex] a \rightarrow \infty [/itex], and show that H acts as though dominated by [itex] \Lambda [/itex] (cosmological constant) ?
[tex] \rho_m \propto \frac{1}{a^3} [/tex]
[tex] H > 0 [/tex]
I'm not sure how to show that H is driven by [itex] \Lambda [/itex], but have tried to sub in the scale factor in place of matter density and make the scale factor go to infinity.
As in,
[tex] H^2 = \frac{8 \pi G }{3 a^3} + \frac{H}{r_c} [/tex]
This gets rid of the [itex] \frac{8 \pi G \rho_m}{3} [/itex] leaving [itex] H = \frac{1}{r_c} [/itex]
What is ##r_c##? Is it constant?
Yes [itex] r_c [/itex] is a constant which is called the cross over scale. I don't think we need to know the value of it
Okay. Now, solve
$$H = \frac{1}{r_c}$$
for the scale factor ##a##.
Alternatively, what is ##H## for a universe that has a non-zero cosmological constant ##\Lambda##, and that is otherwise empty, i.e., that has no matter or radiation content?
ok, so [itex] H = \frac{1}{r_c} [/itex]
[tex] H = \frac{1}{a}\frac{da}{dt} = \frac{1}{r_c} [/tex]
[tex] \int_{0}^{a} \frac{1}{a} da = \int_{0}^{t} \frac{1}{r_c} dt [/tex]
[tex] ln(a) = \frac{1}{r_c} t [/tex]
[tex] a = \exp(\frac{t}{r_c}) [/tex]
Which is akin to dark energy domination [itex] a \propto \exp(Hr_c) [/itex] ?
Related to Solving expansion rate for a variant of the Friedmann equation
1. What is the Friedmann equation?
The Friedmann equation is a fundamental equation in cosmology that describes the expansion of the universe. It was developed by Alexander Friedmann in the 1920s and is based on Einstein's theory of general relativity. It relates the expansion rate of the universe to its density and curvature.
2. How does the Friedmann equation relate to the expansion rate?
The Friedmann equation is a mathematical expression that relates the expansion rate of the universe to its density and curvature. It takes into account the effects of both matter and energy on the expansion rate and is an essential tool for understanding the evolution of the universe.
3. What is a variant of the Friedmann equation?
A variant of the Friedmann equation is a modified version of the original equation that takes into account additional factors or theories. This could include the effects of dark energy, modified gravity, or other cosmological models. These variants are often used to test different theories and make predictions about the expansion rate of the universe.
4. How do scientists solve the expansion rate for a variant of the Friedmann equation?
To solve the expansion rate for a variant of the Friedmann equation, scientists use mathematical techniques and computer simulations. They input different values for the variables in the equation, such as density and curvature, and then compare the results to observations and data from telescopes and other instruments. This helps them to refine the equation and make more accurate predictions about the expansion rate.
5. Why is solving the expansion rate for a variant of the Friedmann equation important?
Solving the expansion rate for a variant of the Friedmann equation is important because it helps us to understand the fundamental properties of the universe. By studying the expansion rate, scientists can gain insight into the composition, evolution, and fate of the universe. It also allows us to test different theories and models for the universe, ultimately leading to a deeper understanding of the cosmos.
