MHB Solving for A and B in p(x) and q(x) to prove A²+3B²=4
  • Thread starter Thread starter anemone
The discussion revolves around proving that for the polynomials p(x) and q(x), the equation A² + 3B² = 4 holds, where A and B are the largest roots of p(x) and q(x), respectively. Participants clarify that cubic polynomials with real coefficients always have at least one real root, countering the notion that the roots could be complex. A detailed approach is provided, showing that the roots of transformed polynomials lead to the conclusion that 4 - A² must equal one of the transformed roots of q(x). Ultimately, it is established that A² + 3B² does indeed equal 4, confirming the original problem statement. The discussion concludes with appreciation for the collaborative problem-solving effort.
anemone
MHB
POTW Director
Problem:
$$p(x)=4x^3-2x^2-15x+9$$
$$q(x)=12x^3+6x^2-7x+1$$
Let A be the largest root of $$p(x)$$ and B the largest root of $$q(x)$$. Show that $$A^2+3B^2=4$$
Hi all, this problem seems to be a little harder than usual for me and I hope someone will give me hint on how to solve it...
Thanks in advance. :)
Mathematics news on Phys.org
Re: Prove that A²+3B²=4.
Hi, I'm not so sure on this one, but the root of p(x) and q(x)
are Complex.
I don't think we can compare complexe number so there is no ''Largest Root''
I'm not 100% certain about this.
Hopefully someone will confirm or show me wrong!
are Complex.
Cubics with real coefficients always have at least one real root, on account of the Intermediate Value Theorem, and the behavior of the fastest-growing term $x^{3}$.
anemone said:
Problem:
You're right, this looks like an unusually hard problem. I have a sort of solution, but I don't believe it can be the best one.
If $\alpha,\ \beta,\ \gamma$ are the roots of $x^3 - px^2 + qx - r$, then the polynomial whose roots are $\alpha^2,\ \beta^2,\ \gamma^2$ is $x^3 - (p^2-2q)x^2 + (q^2-2pr)x - r^2$. The polynomial whose roots are $3\alpha,\ 3\beta,\ 3\gamma$ is $x^3 - 3px^2 + 9qx - 27r$; and the polynomial whose roots are $4-\alpha,\ 4-\beta,\ 4-\gamma$ is $(4-x)^3 -p(4-x)^2 + q(4-x) - r.$ Using those techniques, you can check that if $A,\ A',\ A''$ are the roots of $4x^3-2x^2-15x+9$, then the polynomial with roots $4-A^2, 4-A'^2, 4-A''^2$ is $x^3 - \frac{17}4x^2 + \frac{37}{16}x -\frac3{16}$. If $B,\ B',\ B''$ are the roots of $12x^3 + 6x^2 - 7x + 1$, then the polynomial with roots $3B^2, 3B'^2, 3B''^2$ is exactly the same: $x^3 - \frac{17}4x^2 + \frac{37}{16}x -\frac3{16}$.
This shows that $4-A^2$ must be one of $3B^2, 3B'^2, 3B''^2$, but it doesn't tell you which of those three it is. You know for example that $B$ is the largest root of the polynomial $q(x)$, but that does not mean that $B^2$ is the largest root of the polynomial with roots $3B^2, 3B'^2, 3B''^2$. In fact, each of the given polynomials $p(x)$, $q(x)$ has a negative root that is larger than either of its positive roots. So when you square the roots, the negative root has the largest square. This means that the middle root of $x^3 - \frac{17}4x^2 + \frac{37}{16}x -\frac3{16}$ is the one that is equal to $4-A^2$ and $3B^2$, from which it follows that $A^2+3B^2=4.$
Afterthought: bad notation! After writing this out, I realized that I should not have used the letters $p,\ q,\ r$ for the coefficients in a cubic polynomial, because the given polynomials $p(x)$ and $q(x)$ already used the letters $p$ and $q$.
I finally understand how to solve it now! Thanks again, Opalg for this wonderful approach and I deeply appreciate the time and effort you've spent on solving this problem for me! :)
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
