MHB Solving for a+b+c in $\triangle ABC$
  • Thread starter Thread starter Albert1
To solve for \( a + b + c \) in triangle \( ABC \) with given conditions, the angle \( A \) is \( 60^\circ \), the area is \( 10\sqrt{3} \), and the sum of the squares of the sides is \( 138 \). The area can be expressed using the formula \( \text{Area} = \frac{1}{2}ab\sin(A) \), leading to \( ab = 20 \). Using the Law of Cosines, the relationship \( c^2 = a^2 + b^2 - ab \) can be applied. By substituting known values and solving the resulting equations, \( a + b + c \) can be determined. The final result for \( a + b + c \) is derived from these calculations.
Albert1
$\triangle ABC$ (with side length $a,b,c$)
given :
$(1)\angle A=60^o$
$(2)$ the area of $\triangle ABC=10\sqrt 3$
$(3) a^2+b^2+c^2=138$
please find :$a+b+c=?$
Mathematics news on Phys.org
Re: find a+b+c
given :
$(1)\angle A=60^o$
Area of $\triangle ABC = \frac 1 2 b c \sin 60^\circ = 10\sqrt 3$.
So:
$$bc = 40 \qquad \qquad \qquad \qquad [1]$$
Cosine rule, using [1]:
$$a^2 = b^2+c^2 - 2bc \cos 60^\circ$$
$$a^2 = b^2+c^2 - 2\cdot 40 \cdot \frac 1 2$$
$$b^2+c^2 = a^2 + 40 \qquad \qquad [2]$$
From the given statement with [2]:
$$a^2+b^2+c^2=138$$
$$a^2+(a^2+40)=138$$
$$a=7$$
Back substituting in [2]:
$$b^2+c^2 = 7^2 + 40 = 89 \qquad [3]$$
Note that with [1] and [3]:
$$(b+c)^2 = b^2 + 2bc + c^2 = 89 + 2 \cdot 40 = 169$$
It follows that:
$$b+c = 13$$
And therefore:
$$a+b+c = 7 + 13 = 20$$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
