Solving for a in Logarithmic Equation: x(x-15)=2
  • MHB
  • Thread starter goosey00
  • Tags
    Logarithmic
In summary: Logs are a difficult topic for many students, so don't get discouraged. Keep at it and ask for help when you need it. In summary, the conversation discusses converting a logarithmic expression to an exponential form. The equation log x + (x-15)=2 is transformed using the rule \log a +\log b = \log (ab) and rewritten as \log[x*(x-15)]=2. The base is assumed to be 10 and the definition of logarithms is explained to help understand the process. The importance of understanding logarithms and practicing with them is emphasized.
goosey00
37
In log x + (x-15)=2 and I have to convert it to an exponental. On the practice one they said in the form of log(small)M+log(small)aN=log(small)aM*N
so log(small)ax a^x=x
a=10
Why in this equation does a=10?? I don't understand. In the equation above I understand it being x(x-15)=2 just not the a=10 part Please help
Mathematics news on Phys.org
Re: log./^ help
a=10
Hi goosey00,
Should there be another log? You wrote "log x + (x-15)=2" but I think it might be "log x + log(x-15)=2"
your right. BTW-the other day when we had that long thread, my teacher said I didn't even have to go as far as I did. All that time we spent-really? Oh well.
Ok, so we have \(\displaystyle \log x + \log (x-15)=2\). A rule you need to know, among a couple of others, is \(\displaystyle \log a +\log b = \log (ab)\). You can go the other way as well. So combine the two log expressions into one and then use the definition of log to rewrite the equation. What do you get for that?
Im sorry I am still confused. The end is -2(a*b) right. ??
\(\displaystyle \log[x*(x-15)]=2\)
Assuming log x means base 10, then \(\displaystyle 10^2=x(x-15)\)
Can you go further?
SO, is the rule of a base is 10. You wrote assumed. Thats the confusing part is the 10. I can solve it from there. I just am missing something.
The way logarithms are defined is \(\displaystyle \log_{a}b=x \implies a^x=b\) When there is nothing written in subscript then we can assume it's 10 (in higher math it could mean "e"). For this problem I think it's safe to say the base is 10. However, you need to remember the definition above in order to switch between the log form and exponential form of an expression.
Did your teacher explain what logarithms are and how you can use certain properties to manipulate them?
not really but what you just said completely makes sense now. Thanks again. Jenny
The way to learn logs is to make sure you know and understand the definition that I gave you in my last post. It's just a way to rewrite something in an easier form. So be comfortable writing exponents to logs and logs to exponents. Then you'll be introduced to 3-4 rules that only apply to logs and almost all of the problems you'll see use them. Practice, practice, practice.
FAQ: Solving for a in Logarithmic Equation: x(x-15)=2
What is a logarithmic equation?
A logarithmic equation is an equation in which the variable appears in the exponent. It can be written in the form logb(x) = y, where b is the base and x is the argument or input value. This equation represents the power to which the base must be raised to produce the argument x.
How do I solve for a in a logarithmic equation?
To solve for a in a logarithmic equation, you can use the properties of logarithms to rewrite the equation in a simpler form. Then, you can apply algebraic techniques to isolate the variable a on one side of the equation and solve for its value.
What are the properties of logarithms?
There are three main properties of logarithms that can be used to solve logarithmic equations:
  • The product property: logb(xy) = logb(x) + logb(y)
  • The quotient property: logb(x/y) = logb(x) - logb(y)
  • The power property: logb(xn) = nlogb(x)
What is the domain of a logarithmic equation?
The domain of a logarithmic equation is all real numbers greater than 0. This is because the logarithm of 0 or a negative number is undefined. Therefore, the argument of a logarithmic function must be a positive real number.
Can I use a calculator to solve logarithmic equations?
Yes, you can use a calculator to solve logarithmic equations. Most scientific calculators have a log button that allows you to input the base and argument of a logarithm. Just make sure you are using the correct base and double check your answer with algebraic techniques.
