Solving for $a\times b \times c$: Equations (1), (2), and (3)
  • MHB
  • Thread starter Albert1
In summary, solving for $a\times b \times c$ is important for finding the value of unknown quantities in mathematical equations, which is crucial in many fields of science. The steps for solving equations (1), (2), and (3) involve isolating the variable, using inverse operations, and checking the solution. These equations can be solved simultaneously using methods like substitution, elimination, or graphing. To solve them efficiently, it is helpful to simplify the equations, track the steps, and practice regularly.
Albert1
1,221
$a>0,b>0,c>0$ and :
$ ab+ac=518-----(1)$
$ bc+ab=468-----(2)$
$ ac+bc=650-----(3)$
find :
$a\times b\times c=?$
Mathematics news on Phys.org
Albert said:
$a>0,b>0,c>0$ and :
find :
My solution:
Note that $650=13(50)$ so we get $ac+bc=13(ac-bc)$ which simplifies to $c(14b-12a)=0$, since $c>0$, we get $\dfrac{a}{b}=\dfrac{14}{12}$.
Also note that $650-148=182$ and $\dfrac{182}{468}=\dfrac{7}{18}$. From this we get $\dfrac{ac-ab}{bc+ab}=\dfrac{7}{18}$, i.e. $\dfrac{a(c-b)}{b(c+a)}=\dfrac{7}{18}$ or $\dfrac{14}{12}\left(\dfrac{c-b}{c+\dfrac{14b}{12}}\right)=\dfrac{7}{18}$, which gives $\dfrac{b}{c}=\dfrac{12}{25}$.
So $a,\,b$ and $c$ are in the ratio $14:12:25$ and a check shows that $a=14$, $b=12$ and $c=25$ satisfy the given system and so $abc=4200$.
anemone said:
My solution:
very good!
Albert said:
$a>0,b>0,c>0$ and :
find :
\(\displaystyle (3)-(2)\Rightarrow ac-ab=182\,(4)\)
\(\displaystyle (4)+(1)\Rightarrow2ac=700\Rightarrow ac=350\)
\(\displaystyle \Rightarrow bc=300\)
\(\displaystyle \Rightarrow ab=168\)
\(\displaystyle a^2b^2c^2=350\cdot300\cdot168=2\cdot5^2\cdot7\cdot2^2\cdot3\cdot5^2\cdot2^3\cdot3\cdot7\)
\(\displaystyle abc=2^3\cdot3\cdot5^2\cdot7=4200\)
nice solution!
add all three to get
$2(ab+bc+ca) = 1636$
or $ab+bc+ca = 818$
subtracting the 3 given equations we get
$bc= 300,ca=350,ab= 168$
multiply above 3 to get
$(abc)^2= 300 * 350 * 168 = 50 * 6 * 50 * 7 * 42 * 4 = 50^2 * 42^2 * 2^2$
or $abc= 50 * 42 *2 = 4200$
or $ab+bc+ca = 818$
nice job!
FAQ: Solving for $a\times b \times c$: Equations (1), (2), and (3)
What is the importance of solving for $a\times b \times c$?
Solving for $a\times b \times c$ is important because it allows us to find the value of a variable or unknown quantity in a mathematical equation. This is essential in many fields of science, such as physics, chemistry, and engineering, where precise calculations are necessary.
What are the steps for solving equations (1), (2), and (3)?
The steps for solving equations (1), (2), and (3) are as follows:
  1. Isolate the variable or unknown quantity on one side of the equation.
  2. Use inverse operations to simplify the equation and eliminate any coefficients or constants.
  3. If necessary, combine like terms and simplify the equation further.
  4. Check your solution by plugging it back into the original equation and ensuring that it satisfies the equation.
Can equations (1), (2), and (3) be solved simultaneously?
Yes, equations (1), (2), and (3) can be solved simultaneously if they have the same variables and can be rearranged to form a system of equations. This is often done using methods such as substitution or elimination to find a solution that satisfies all three equations.
What are some common methods for solving equations (1), (2), and (3)?
Some common methods for solving equations (1), (2), and (3) include:
  • Substitution: This method involves solving one equation for a variable and substituting that value into the other equations.
  • Elimination: This method involves adding or subtracting the equations to eliminate one variable at a time.
  • Graphing: This method involves graphing each equation on the same coordinate plane and finding the point of intersection.
What are some tips for solving equations (1), (2), and (3) efficiently?
Here are some tips for solving equations (1), (2), and (3) efficiently:
  • Simplify the equations before attempting to solve them by combining like terms and eliminating any unnecessary coefficients or constants.
  • Keep track of the steps you take to solve the equations, especially if you are solving them simultaneously.
  • Always check your solution by plugging it back into the original equations to ensure that it satisfies all three equations.
  • Practice regularly to improve your problem-solving skills and become more efficient at solving equations.
