Solving for a variable in an equation that involves vectors
In summary, the problem involves finding the value of Q2 in the standard electric force equation for 2 charges, given the values of all other variables. The approach involves using the unit vector \hat{r}_{2,1} and taking the dot product with both sides of the equation to eliminate the vectors, resulting in a scalar equation. The Coulomb Law can then be written in x,y,z components to solve for Q2.
Chetlin
36
I have the equation:
[tex]\mathbf{F}_{2,1} = \frac{Q_1 Q_2}{4 \pi \varepsilon_0 {r_{2,1}}^2}\hat{r}_{2,1}[/tex] (standard electric force equation for 2 charges)
I know the value of everything except Q2 and have to find it. The vectors each have 3 components.
Normally in an algebraic equation, I would just solve for a variable by isolating it on one side of the = sign. But this equation involves vectors and I don't think there is a way to divide vectors. I could also subtract F2,1 from both sides which at least gets everything onto one side but I am still left with the vectors. I will effectively have three equations (one for each component of the vectors), but only one variable I have to solve for, right? Does the nature of this problem (it is physical) make it so that only certain vectors are even possible, so if I were to tweak F2,1 and not change the value of anything else, the problem would become impossible to solve because it would represent a physical impossibility?
Nothing really
I used only the x component of each vector and solved it using that equation and got the correct answer. But like I said before, if I tweaked only the y component of F2,1, the equation that used only the x components would be the same (so I'd get the same result) but the entire vector equation would not.
r212 is not vector, but scalar. It is possible to divide with it. F2,1 is parallel with the unit vector ##\hat{r}_{2,1}## , a scalar multiple of it.
What were the data? You should determine r212 from the coordinates.
ehild
Likes 1 person
ehild
That's true, but [itex]\hat{r}_{2,1}[/itex] is a vector, and I would want that to be on the other side as well. I just realized what I tried to do is impossible, because it would result in a scalar on one side of the = sign, and whatever you would (imaginatively) get if you divided two vectors, on the other side.
I'm starting to believe that any problem like this would be set up very specifically, and that only certain values will work at all, allowing me to just use one component of the vectors.
Edit: oops, I see you were still writing when I posted this.. sorry for jumping the gun so quickly, haha :P
Edit 2:
ehild said:
F2,1 is parallel with the unit vector [itex]\hat { r}_{2,1}[/itex] , a scalar multiple of it.
Oh dang, you're right. So you can't just tweak one component of F2,1.. doing that would prevent them from being parallel and would cause all kinds of issues. This is just a simple equation of a vector being equal to a magnitude times a direction unit vector. Sorry, it's been a little while since I've really worked with vectors in such a way, so I've been spending a lot of time on issues like this. Thanks again, very much!
You can not put ##\hat{r}_{2,1}## on the other side. But you know that ##\vec{F}_{2,1}## is a scalar multiple of ##\hat{r}_{2,1}##, and that holds for all corresponding coordinates.
It would be better to see the whole text of the problem.
ehild
Well, I have my question answered, but to be complete, here is the text of the problem. It's from an old Schaum's Outlines book from the early 1980's.
Point charge Q1 = 300 µC, located at (1, −1, −3) m, experiences a force F2,1 = (8, −8, 4) N due to point charge Q2 at (3, −3, −2) m. Determine Q2.
What you do is dot both sides of the equation by [itex]\hat{r}_{2,1}[/itex]. This will give you the scalar equation you desire. Do you know how to determine [itex]\hat{r}_{2,1}[/itex]?
Chet
Likes 1 person
Yep, that unit vector is just the vector r2,1 divided by its magnitude ([itex] \hat{r}_{2,1} = \frac{1}{r_{2,1}}\mathbf{r}_{2,1}[/itex], where [itex]r_{2,1} = ||\mathbf{r}_{2,1}|| = \sqrt{{r_{{2,1}_x}}^2 + {r_{{2,1}_y}}^2 + {r_{{2,1}_z}}^2}[/itex]). Sorry for the really weird notation inside the square root sign.
That's a really neat trick, thanks for showing it to me. I never thought to use scalar products to get rid of the vectors, and of course the scalar product of any unit vector with itself is 1.
The point charge Q1 experiences force from Q2:
[tex]\vec F = k \frac {Q_1 Q_2}{(\vec r_1-\vec r_2)^2} \hat r_{12} [/tex]
where ##\hat r_{12}=\frac{\vec r_1-\vec r_2} {|\vec r_1-\vec r_2|}##
In your problem, r12=(1, −1, −3)-(3, −3, −2)=(-2, 2, -1). The magnitude is 3, so the components of ##\hat r_{12} ## are (-2/3, 2/3, -1/3)
The force is F= (8, −8, 4) N. You see that the force is parallel to ##\hat r_{12} ##.
You can write out the Coulomb Law in x,y,z components:
[tex]F_x=8=\frac {kQ_1Q_2}{r_{12}^2}(-2/3)[/tex]
[tex]F_y=-8=\frac {kQ_1Q_2}{r_{12}^2}(2/3)[/tex]
[tex]F_z=4=\frac {kQ_1Q_2}{r_{12}^2}(-1/3)[/tex]
You see that you get the same value for ##kQ1Q2/ {r_{12}^2}## from each equation, it is -12. kQ1Q2/9=-12. That is a scalar equation already.
ehild
Related to Solving for a variable in an equation that involves vectors
1. How do you solve for a variable in an equation that involves vectors?
In order to solve for a variable in an equation that involves vectors, you must first isolate the variable on one side of the equation. Then, use vector operations such as addition, subtraction, and scalar multiplication to manipulate the vector variables until you can solve for the unknown variable.
2. Can I use the same methods for solving equations with scalars to solve equations with vectors?
No, the methods for solving equations with vectors are slightly different due to the fact that vectors have both magnitude and direction. You must use vector operations to manipulate the variables and solve for the unknown.
3. What is the importance of solving for a variable in an equation that involves vectors?
Solving for a variable in an equation that involves vectors allows you to find the specific values of the variables that satisfy the equation. This is crucial in many fields of science, such as physics and engineering, where vector equations are commonly used.
4. Are there any special rules or properties for solving equations with vectors?
Yes, there are a few rules and properties that are specific to solving equations with vectors. For example, the commutative and associative properties of addition and multiplication still apply, but the distributive property does not. Additionally, the direction of a vector can change when multiplied by a negative scalar.
5. What should I do if I encounter a vector equation with multiple unknown variables?
If you have a vector equation with multiple unknown variables, you will need to use multiple equations to solve for each variable. This is because vectors have both magnitude and direction, so you need enough information to solve for each unknown in each direction.
  • General Math
