MHB Solving for an exponential equation using logarithms 16^{x}-5(4)^{x}-6=0
The discussion revolves around solving the exponential equation 16^x - 5(4)^x - 6 = 0. The original poster struggles with applying logarithmic properties correctly and is confused about arriving at the solution log4(6). Another participant suggests rewriting the equation as a quadratic in terms of 4^x, which simplifies the problem. This approach allows the use of the quadratic formula to find the solution. The conversation concludes with the poster expressing gratitude for the clarification.
sp3
Hello I'm having trouble solving for this exponential equation : 16^{x}-(5,4)^{x}-6=0
I used some logarithms properties but can't get anything close to the following solutions here View attachment 8366
I tried using log base 16 : log16(16^{x})-6=log16((5,4)^{x}) ; then x - xlog16(5,4)=6 ;
factorizing x : x(1-log16(5,4))=6 here I get lost... I don't know how they got to log base 4 ( the answer is log4(6)) ... i thought about rewriting 5,4 as a fraction 27/5 but it doesn't help a lot... thanks in advance for the help
Mathematics news on Phys.org
Are you sure you've copied the equation correctly? According to W|A, the solution to the given equation is
$$x=0.833215$$
But:
$$\log_4(6)\approx1.292481250360578$$
Hi sp3, welcome to MHB! ;)
Can it be that your equation should be $16^x-5\cdot 4^x-6=0$?
If so then we can write it as $(4^x)^2-5(4^x)-6=0$ and apply the quadratic formula.
Thank youu I suspected something was up with this decimal number... thanks a million times guys! :D
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
