MHB Solving for $f(600)$ Given $f(500)=3$
  • Thread starter Thread starter Albert1
The function f satisfies the property f(xy) = f(x)/y for all x, y > 0, and it is given that f(500) = 3. To find f(600), x is set to 500 and y is calculated as 600/500, which equals 6/5. This leads to the calculation f(600) = f(500)/(6/5), resulting in f(600) = 5/2. The discussion highlights the simplicity of the solution, with participants expressing surprise at the straightforwardness of the problem.
Albert1
given a function $f$, satisfying :
(1) $f(xy)=\dfrac {f(x)}{y}$ for all $x,y>0$
(2) $f(500)=3$
what is the value of $f(600)$
Mathematics news on Phys.org
(2) $f(500)=3$
Is this a trick question or did I just stumble upon a quick way to do this? I usually go insane when you post one of these.
[sp]
[math]f(xy) = \frac{f(x)}{y}[/math]
Let x = 500 and xy = 600. Then y = 600/500 = 6/5.
Thus
[math]f(600) = \frac{f(500)}{\frac{6}{5}} = \frac{3}{\frac{6}{5}} = \frac{5}{2}[/math]
[/sp]
-Dan
[sp]
Thus
[/sp]
-Dan
please don't go insane,your answer is correct,thanks for participating.
By the way ,do you prefer more challenging problems (need a lot of tricks)?
I don't usually lack self-confidence but whenever I can quickly answer a problem from you or the POTWs I get the feeling I've overlooked a critical point! Like this one...I wasn't expecting a one line solution so I was unsure about it. Personally I prefer the challenge, though I usually don't post my attempts. I like these. (Yes)
-Dan
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
