Solving for n: 4 Divisors & n+1 Formula
  • MHB
  • Thread starter Albert1
  • Tags
    Formula
In summary, the formula for solving for n with 4 divisors and n+1 formula is n = (a - 1)(b - 1)(c - 1), where a, b, and c are prime numbers. To use the formula, you need to find three different prime numbers and the result will not be accurate if you use non-prime numbers. The n+1 in the formula represents the number itself, which is always a divisor. To solve for n, simply plug in the values of a, b, and c into the formula and solve for n.
Albert1
1,221
we are given :
(1)n $\in N$
(2) n has exactly 4 positive divisors (including 1 and n)
(3)n+1 is four times the sum of the other two divisors
please find all n
Mathematics news on Phys.org
Albert said:
we are given :
(1)n $\in N$
please find all n
Let other 2 factors be a,b. without loss of generality a < b Note that a and b both must be prime otherwise >2 other divisors or > 4 divisors
from given condition
$n= ab$
$n+1 = 4(a+b)$
or $ab +1 = 4a + 4b$
or $ab-4a - 4b + 1 = 0$
or $(a-4)(b-4) = 15= 1 * 15= 3 * 5$
$(a-4) = 1 , b = 4 = 15=> a = 5, b= 19=>n= 95$
$a-4 = 3 , b-4 = 5 => b= 9$ hence b is not prime
so only solution
$n = 95$
$n= ab$
$n+1 = 4(a+b)$
so only solution
$n = 95$
yes , you are right
FAQ: Solving for n: 4 Divisors & n+1 Formula
What is the formula for solving for n with 4 divisors and n+1 formula?
The formula for solving for n with 4 divisors and n+1 formula is: n = (a - 1)(b - 1)(c - 1), where a, b, and c are prime numbers.
How do I know which numbers to use for a, b, and c in the formula?
To use the formula, you need to find three different prime numbers. Prime numbers are numbers that are only divisible by 1 and themselves. Examples of prime numbers are 2, 3, 5, 7, 11, etc.
Can I use non-prime numbers in the formula?
No, the formula only works with prime numbers. If you use non-prime numbers, the result will not be accurate.
What is the significance of n+1 in the formula?
The n+1 in the formula represents the number itself, which is always a divisor. This is why the formula is called 4 divisors and n+1 formula.
How do I solve for n using the formula?
To solve for n, simply plug in the values of a, b, and c into the formula and solve for n. For example, if a = 2, b = 3, and c = 5, then n = (2-1)(3-1)(5-1) = 4.
