MHB Solving for Optimal Advertising Units in Managerial Economics
  • Thread starter Thread starter HighAllegiant
    Economics
The discussion focuses on maximizing sales through optimal advertising units in managerial economics, specifically using a regression analysis model. The solution for maximizing sales without constraints was found to be 15 units for TV and 20 units for magazines. However, when faced with a budget constraint of 31 units, the optimal advertising levels were determined to be 13 units for TV and 18 units for magazines. The use of the Lagrangian method was suggested for solving the constrained optimization problem, despite initial confusion over the absence of prices for the advertising units. Ultimately, the conversation highlights the challenges of applying theoretical methods to practical problems without complete information.
HighAllegiant
[SOLVED] Managerial Economics Problem
SOLVED
A firm has decided through regression analysis that its sales (S) are a function of the amount of advertising (measured in units) in two different media, television (x) and magazines (y):
S(x, y) = 100 – x
2 + 30x – y2 + 40y
(a) Find the level of TV and magazine advertising units that maximizes the firm's sales.
(b) Suppose that the advertising budget is restricted to 31 units. Determine the level of advertising (in units) that maximizes sales subject to this budget constraint.
(c) Give an economic interpretation for the value of the Lagrangian Multiplier obtained in part (b) above.
I already solved (a) by finding the derivative with respect to (x,y) and equating to 0.
(a) X* = 15, Y* = 20
My prof provided the answer to (b) and I have absolutely no idea to how he arrived at it.
I assumed the the Income(M)=31 but without any given prices for (x,y), I cannot seem to apply it into a Lagrangian method.
(I'm assuming I use the Lagrangian method because it was the most recent lecture to this question. (c) also asks a follow up question which requires the Langrangian multiplier.)
Could anyone help me?
(b) X* = 13, Y* = 18
Mathematics news on Phys.org
Try $x+y=31$, and plug this into your sales function, thus reducing it to a function of a single variable. The bounds on $x$, say, are $x\in[0,31]$. Use the standard Calculus I technique for maximization.
Thanks.
I just realized that I had been so used to my instructor's problems where he provides the prices for each product that I had no idea what to do when he doesn't give any prices.
(It works on problems which are similar to the one I just asked for.)
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
