Solving for Positive Integer $x$ and $y$ in $\dfrac{2^x}{y!}$
In summary, the purpose of solving for positive integer x and y in the equation $\dfrac{2^x}{y!}$ is to find the values of x and y that make the equation true. The possible values of x and y are positive integers, where y must be less than x. To solve for x and y, algebraic manipulation and trial and error can be used. There can be multiple solutions for this equation. Real-world applications of solving for x and y in this equation include calculating combinations in a lottery and determining probabilities in fields such as genetics and statistics.
anemone
MHB
POTW Director
3,883
115
If $\dfrac{1}{9!1!}+\dfrac{1}{7!3!}+\dfrac{1}{5!5!}+\dfrac{1}{3!7!}+\dfrac{1}{1!9!}=\dfrac{2^x}{y!}$ find $x,\,y$ where they are positive integers.
Mathematics news on Phys.org
Multiply through by $9!$ to get:
$$1 + 2^2 \cdot 3 + \frac{2 \cdot 3^2 \cdot 7}{5} + 2^2 \cdot 3 + 1 = \frac{2^x \cdot 9!}{y!}$$
Simplfying a bit, we get:
$$\frac{2 \cdot 5 + 2^3 \cdot 3 \cdot 5 + 2 \cdot 3^2 \cdot 7}{5} = \frac{2^x \cdot 9!}{y!}$$
Now note that the numerator in the LHS happens to equal $256 = 2^8$ hence:
$$\frac{2^8}{5} = \frac{2^x 9!}{y!}$$
And so the solution must satisfy:
$$y! = 2^{x - 8} \cdot 5 \cdot 9!$$
Observe that $y \geq 10$ since there are two factors of 5 in the RHS, and that $y < 11$ since 11 is prime and so does not divide the RHS. Thus it follows that $y = 10$, and we get:
$$10! = 2^{x - 8} \cdot 5 \cdot 9! ~ ~ ~ \implies ~ ~ ~ 2 \cdot 5 = 2^{x - 8} \cdot 5 ~ ~~ \implies ~ ~ ~ x = 9$$
So the solution is $(x, y) = (9, 10)$.
It's not too tedious to construct Pascal's triangle for this one.
\(\displaystyle \frac{1}{9!1!}+\frac{1}{7!3!}+\frac{1}{5!5!}+\frac{1}{3!7!}+\frac{1}{1!9!}=\frac{1}{10!}\sum_{n=0}^4\binom{10}{2n+1}=\frac{2^9}{10!}\Rightarrow(x,y)=(9,10)\)
Thanks to both of you for participating and providing us those awesome solutions! :cool::)
I would approach this problem by first understanding the given equation and identifying any patterns or relationships between the numbers involved. The expression on the left side of the equation can be rewritten as a sum of fractions with a common denominator of $9!$:
$$\dfrac{1}{9!1!}+\dfrac{1}{7!3!}+\dfrac{1}{5!5!}+\dfrac{1}{3!7!}+\dfrac{1}{1!9!} = \dfrac{9}{9!}+\dfrac{35}{9!}+\dfrac{21}{9!}+\dfrac{35}{9!}+\dfrac{9}{9!} = \dfrac{109}{9!}$$
We can also express the right side of the equation in a similar way, by using the formula for $y! = y\times(y-1)\times(y-2)\times\dots\times3\times2\times1$:
$$\dfrac{2^x}{y!} = \dfrac{2^x}{y\times(y-1)\times(y-2)\times\dots\times3\times2\times1}$$
From this, we can see that the denominator of the right side will always be a multiple of $9!$, since it includes all the numbers from $1$ to $y$. This means that $y$ must be a positive integer that is a multiple of $9$, since the denominator of the left side is also $9!$.
Now, let's look at the numerator of the right side, $2^x$. We know that $2^x$ is the product of $x$ twos, so it must be a multiple of $2$. However, since the denominator of the left side is $9!$, which includes all the numbers from $1$ to $9$, we can see that $2^x$ must also be a multiple of $9$. This means that $x$ must be greater than or equal to $2$, since $2^1 = 2$ is not a multiple of $9$.
To summarize, we have determined that $y$ must be a positive integer that is a multiple of $9$, and $x$ must be a positive integer greater than or equal to $2
FAQ: Solving for Positive Integer $x$ and $y$ in $\dfrac{2^x}{y!}$
What is the purpose of solving for positive integer x and y in the equation $\dfrac{2^x}{y!}$?
The purpose of solving for positive integer x and y in this equation is to find the values of x and y that make the equation true. This can be useful in various mathematical and scientific applications, such as determining the number of possible outcomes in a combination or permutation problem.
What are the possible values of x and y in $\dfrac{2^x}{y!}$?
The values of x and y in this equation must be positive integers. This means that they can take on any whole number value greater than zero, such as 1, 2, 3, etc. Additionally, y cannot be equal to or greater than x, as this would result in a division by zero error.
How do I solve for x and y in the equation $\dfrac{2^x}{y!}$?
To solve for x and y, you can use algebraic manipulation and basic arithmetic operations. For example, you can rewrite the equation as $2^x = y!$ and then use logarithms to solve for x. Alternatively, you can use trial and error by plugging in different values for x and y until you find a combination that satisfies the equation.
Can there be multiple solutions to $\dfrac{2^x}{y!}$?
Yes, there can be multiple solutions to this equation. For example, if x = 3 and y = 2, the equation becomes $\dfrac{2^3}{2!} = 4$. However, if x = 4 and y = 3, the equation still holds true. Therefore, there are multiple combinations of x and y that can satisfy the equation.
What are some real-world applications of solving for x and y in $\dfrac{2^x}{y!}$?
Solving for x and y in this equation can be useful in various real-world applications, such as calculating the number of possible combinations in a lottery or the number of ways to arrange a set of objects. It can also be used in fields such as genetics and statistics to determine the probability of certain outcomes.
