Solving for Real Solutions: x^2 − 10x + 1 = (x + 1)√x
  • MHB
  • Thread starter anemone
In summary, "solve for real solutions" refers to finding the values of variables that make an equation true, and these values are known as "real solutions" because they exist on the real number line. It is important to solve for real solutions as it allows for precise calculations in scientific fields. Methods such as substitution, elimination, and graphing can be used to solve for real solutions, but common mistakes include forgetting to check for extraneous solutions and making errors in algebraic manipulation. To improve skills in solving for real solutions, practice and familiarization with different types of equations and methods is recommended, along with seeking guidance from a teacher or tutor.
anemone
MHB
POTW Director
3,883
115
Solve for real solutions of $x^2 − 10x + 1 = (x + 1)\sqrt{x}$.
Mathematics news on Phys.org
My solution:
Squaring both sides and rearranging terms:$(x^2-10x+1)^2=((x+1)\sqrt{x})^2 \Rightarrow x^4-21x^3+100x-21x+1 = 0$
The last expression implies a product of the form: $(x^2+ax+1)(x^2+bx + 1)=0$
Multiplying and comparing coefficients:
$(x^2+ax+1)(x^2+bx + 1) = x^4 + (a+b)x^3+(2+a\cdot b)x^2+(a+b)x + 1=0$
It is easy to see, that $a = -7$ and $b = -14$ is the only pair of integers, which ensure the identity.
So, we have: $x^4-21x^3+100x-21x+1 = (x^2-7x+1)(x^2-14x+1) = 0$
The four positive roots to be evaluated are:\[\left \{ \frac{1}{2}(7\pm 3\sqrt{5}), 7\pm 4\sqrt{3} \right \}\]Both roots: $\left \{ \frac{1}{2}(7 + 3\sqrt{5}), \frac{1}{2}(7 - 3\sqrt{5})\right \}$ imply, that $x^2-10x+1 < 0$, but the RHS: $(x+1)\sqrt{x} > 0$. These roots would be valid, if we had the squared version ($4th$ degree polynomial) as starting point.The two other roots preserve the plus sign in $x^2-10x+1$, and therefore, $\left \{ 7\pm 4\sqrt{3}\right \}$ are the only valid roots.
Well done lfdahl, and thanks for participating!(Cool)
My solution:
Rewrite the original equation as
$(x+1)^2-12x = \sqrt{(x + 1)^2}\sqrt{x}$
Next, let $u=(x+1)^2$ then the equation above turns into $u-12x=\sqrt{u}\sqrt{x}$, or $ u-\sqrt{u}\sqrt{x}-12x=0$, which can be factorized into $(\sqrt{u}-4\sqrt{x}) (\sqrt{u}+3\sqrt{x})=0$, which suggests $u=16x$ and back substitute $u=(x+1)^2$ into $u=16x$ yields $x^2-14x+1=0$, i.e. $x=7\pm 4\sqrt{3}$.
FAQ: Solving for Real Solutions: x^2 − 10x + 1 = (x + 1)√x
What does "solve for real solutions" mean?
"Solve for real solutions" is a mathematical concept that refers to finding the values of a variable or variables that make an equation true. These values are known as "real solutions" because they are numbers that exist on the real number line.
Why is it important to solve for real solutions?
Solving for real solutions is important because it allows us to find the exact solutions to mathematical problems. This can be useful in many areas of science, such as physics and engineering, where precise calculations are necessary.
What methods are used to solve for real solutions?
There are several methods that can be used to solve for real solutions, including substitution, elimination, and graphing. These methods rely on algebraic manipulation and logical reasoning to determine the values of the variables in an equation.
What are some common mistakes when solving for real solutions?
One common mistake when solving for real solutions is forgetting to check for extraneous solutions. These are solutions that satisfy the equation but do not make sense in the given context. Another mistake is making errors in algebraic manipulation, which can lead to incorrect solutions.
How can I improve my skills in solving for real solutions?
To improve your skills in solving for real solutions, it is important to practice regularly and familiarize yourself with different types of equations and methods for solving them. It can also be helpful to work through problems step-by-step and seek guidance from a teacher or tutor if needed.
