Solving for Refraction Angle of Light Ray Across Parallel Plate
In summary, the problem at hand involves a parallel, transparent plate with a refractive index that varies along the x-direction. The goal is to find the index of refraction where a light ray exits the plate at a 30 degree angle from the normal. This cannot be solved using Snell's Law, but instead requires the use of Fermat's Principle and the calculus of variations. The index of refraction can be determined by finding the path that minimizes the time it takes for the light ray to travel through the plate.
function4
We have a parallel, transparent plate. The plate has an incidence of refraction that is dependent on a transverse coordinate. (i.e. the plate is perpendicular to z direction, and the refractive index changes along x direction)
n(x) = 1.5/(1 - x/0.13)
It is observed that when a light ray is perpendicularly incident on the plate (from the air) at x=0, it emerges on the other side of the plate, making a 30 degree angle from the normal.
Find the index of refraction where the ray exits. (Thickness of the plate is not known)
I'm not really sure about this. Snell's law tells us that the light ray should stay perpendicular to the normal across both boundaries, so there is something I am clearly missing.
Snell's Law: n1*sin(a1) = n2*sin(a2)
Where n1 and n2 are indices of refraction for the two materials
a1, a2 are the angles the ray makes from the normal of the material
Again, using Snell's Law, at the second boundary (going from plate back to air), we know that n1 = n(x), n2 = 1, a1 = ?, a2 = 30 deg
This is one equation with two unknowns, so I am stuck.
If for some reason, the light were to bend at the first boundary, then I would treat the plate as a bunch of thin plates, and integrate (as the light ray would be experiencing a different index of refraction as it traveled through the plate).
In order for the ray to be emerging at a 30 degree angle, something like this must be happening, but I don't know why!
Any help is appreciated!
Hello!
I can see why you are stuck on this problem. It is not a straightforward application of Snell's Law, as you have correctly identified. The reason for this is because the index of refraction is changing along the x-direction, so the light ray is experiencing different indices of refraction as it travels through the plate.
To solve this problem, we need to use the concept of Fermat's Principle, which states that light will travel the path that takes the least amount of time. In this case, the light ray will take the path that minimizes the time it takes to travel through the plate.
To find the index of refraction where the ray exits, we need to find the path that takes the least amount of time. This can be done by using the calculus of variations, which involves minimizing a functional. In this case, the functional is the time it takes for the light ray to travel through the plate.
Using the calculus of variations, we can find the path that minimizes the time, and from there, we can determine the index of refraction at that point. This will give us the answer to the problem.
I hope this helps! Let me know if you have any further questions. Good luck with your problem solving!
Related to Solving for Refraction Angle of Light Ray Across Parallel Plate
1. What is refraction angle of a light ray?
The refraction angle of a light ray is the angle between the direction of the light ray after it has passed through a medium, and the normal line perpendicular to the surface of the medium at the point of incidence.
2. What is the formula for solving for refraction angle of a light ray?
The formula for solving for refraction angle of a light ray is n1sinθ1 = n2sinθ2, where n1 and n2 are the refractive indices of the two media, and θ1 and θ2 are the angles of incidence and refraction, respectively.
3. How do parallel plates affect the refraction angle of a light ray?
Parallel plates do not change the refraction angle of a light ray, but they can cause the light ray to undergo multiple refractions as it passes through each plate. The overall refraction angle will depend on the combined effect of all the refractions.
4. How does the thickness of the parallel plates affect the refraction angle?
The thickness of the parallel plates does not have a direct effect on the refraction angle, but it can indirectly affect it by changing the number of refractions the light ray undergoes and the distance it travels through the medium.
5. What factors can affect the accuracy of solving for the refraction angle of a light ray across parallel plates?
The accuracy of solving for the refraction angle of a light ray across parallel plates can be affected by factors such as the accuracy of the measured angles of incidence and refraction, the refractive indices of the media, and any external factors that may cause deviations from the expected path of the light ray.
