MHB Solving for Roots of a Cubic Equation Using Perturbation Theory
The discussion focuses on finding two-term expansions for the roots of the cubic equation x^3 + x^2 - w = 0, particularly for small values of w. One participant has identified one root near -1 and seeks guidance on determining the expansions for the other two roots, which are near 0 and 1. The conversation emphasizes the use of perturbation theory and suggests trial solutions involving powers of w to derive the correct asymptotic sequences. Participants clarify that the approach is not merely guessing but involves systematic trial solutions to find coefficients and exponents. The thread highlights the importance of understanding perturbation expansions in solving such equations.
Poirot1
Question: obtain 2-term expansions for the roots of x^3+x^2-w=0 , 0<w<<1.
I assumed an expansion of the form x=a+bw+... and from this obtained a=-1, b=1 as one solution. How do I work out the form of the other 2 expansions?
Thanks.
Mathematics news on Phys.org
Thanks.
There are two roots near 0 and one root near 1, you have already dealt with than near 1. Then for the roots near 0 guess a trial solution: \(x=aw^k\) (which is a two term logarithmic expansion: \(\log(x)=A+B\log(w)\) ).
CB
sorry Captain Black, are you familiar with perturbation expansions? That is what I'm doing, I should have said the above solution as
x= -1+w+... as it is an infinite (perturbation) series. I want to know how to arrive at the correct asymptotic sequence.
Sorry Poirot, are you familiar with singular perturbation expansions?
When you find the correct exponent for the trial solution you can use a perturbation expansion for \(a=a_0+a_1w^{k}+...\), where \(a_0\) is one or other of the two zeroth-order coefficients found using the trial solution.
CB
I take it you thought I was trying to be funny. Anyway, is there any way to arrive at the correct answer without just guessing?
It is not a guess. There can be no constant term since the root is going to zero as \(w\) goes to zero, so the simplest candidate is a multiple of some power of \(w\). Try the candidate , find the coefficient and exponent for an initial approximate solution and take it from there.
CB
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
