James Brady
- 105
- 4
So I'm trying to figure out how we got the allowed vibrational energy levels for a diatomic molecule by approximating it with simple harmonic motion.
I do know how to use the uncertainty principle to get the zero-point energy:
We know that the potential function is ##V(x) = \frac{1}{2}mx^2## where x is the distance away from the equilibrium:
1) Knowing that ##k \Delta X^2 = \frac{\Delta P^2}{m}##
##\Delta X = \frac{\Delta P}{\sqrt{km}}##
So that's one Delta X, the other one you can get from the uncertainty principle:
##\Delta X \Delta P \geq \frac{\hbar}{2}## therefore ##\Delta X = \frac{\hbar}{2 \Delta P}## at a minimum
These two values for delta x and inserted back into the original energy equation:
##V(x) = \frac{1}{2}m\frac{\Delta P}{\sqrt{km}}\frac{\hbar}{2 \Delta P}##
Delta P cancel out, multiply both numerator and denominator by k squared and you get the zero point energy:
##E_0 = \frac{\hbar}{2} \omega##
So that's one energy level, how do I find the rest? If I start with just the Schrodinger equation:
##(-\frac{\hbar}{2m} \frac{d}{dx^2} + \frac{1}{2}kx^2)\psi(x) = E \psi(x) ##
I get that, but it's not so easy to solve, I know the answer should be: ##E = \hbar \omega(n + 1/2), n = 0,1,2...##
Also, how would I find which energy level the system is in based on temperature, the only thing I can think of right now is Botlzman ##E = \frac{3}{2}kT##, but I understand that much of this energy can be in the form of translational, rotational or oscillation, so...
