MHB Solving for simultaneous equations
The simultaneous equations given have been shown to have no real solutions through a series of substitutions and cubic equations. Specifically, it was established that the cubic derived from the equations has only one real root, indicating that at least one of the variables must be complex. For part (ii), the value of a^4 + b^4 + c^4 was calculated using recursion and Newton's identities, resulting in a final value of 25/6. The calculations confirmed that the relationships between the sums of powers and products of the variables align with the derived values. Thus, the problem demonstrates the interplay between algebraic identities and the nature of solutions in simultaneous equations.
Albert1
( i ) prove the following simultaneous equations (1) (2) and (3) has no real solution
$a+b+c=1-----(1)$
$a^2+b^2+c^2=2----(2)$
$a^3+b^3+c^3=3----(3)$
( ii ) using (1)(2)and(3)find the value of :
$a^4+b^4+c^4$
Mathematics news on Phys.org
Re: solving for simultaneous equations
Here's my solution to part (i). Not really the most elegant but gets it done. Solving eqn (1) for $c$ and substituting into the remaining two equations gives (with appropriate scaling)
$b^2 +(a-1)b +a^2-a-\dfrac{1}{2} = 0$
$(a-1)b^2+(a-1)^2b-a^2+a+\dfrac{2}{3}=0$
Eliminating $b$ between these two gives that $a$ satisfies the cubic
$6a^3-6a^2-3a-1 = 0$
Via a variety of techniques we can show that this cubic has only one real root and it's lies in the interval $(1,2)$ so $a > 1$.
Next we will show that the first equation for $b$ has complex roots for this value of $a$. To show this is to show that
$(a-1)^2 - 4(a^2-a-\dfrac{1}{2}) < 0$ or $-3a^2+2a+3 < 0$
As $a$ satisfies this cubic then
$-3a^2+2a+\dfrac{3}{2} = - \dfrac{1}{2a} - a + \dfrac{3}{2} < 0$ if $a > 1.$
The latter part can be established as follows: Let $f(a) =- \dfrac{1}{2a} - a + \dfrac{3}{2} $. Since $f(1) = 0$ and $f'(a) <0$ if $a>1$ then $f(a) < 0$ for $a>1$.
I'll take a stab at part (ii):
From the form of the given expressions, we may use an auxiliary equation of:
[math](r-a)(r-b)(r-c)=r^3-(a+b+c)r^2+(ab+ac+bc)r-abc=0[/math]
to determine the linear homogeneous recursion:
[math]S_{n+3}=(a+b+c)S_{n+2}-(ab+ac+bc)S_{n+1}+abcS_{n}[/math]
where we are given:
[math]S_1=1,\,S_2=2,\,S_3=3[/math]
If we square (1), we find:
$$(a^2+b^2+c^2)+2(ab+ac+bc)=1$$
Using (2), this becomes:
$$2+2(ab+ac+bc)=1$$
Hence:
$$ab+ac+bc=-\frac{1}{2}$$
If we cube (1), we find:
$$(a^3+b^3+c^3)+3(a+b+c)(ab+ac+bc)-3abc=1$$
Using (3) and our previous result, this becomes:
$$3-\frac{3}{2}-3abc=1$$
Hence:
$$abc=\frac{1}{6}$$
And so our recursion becomes:
[math]S_{n+3}=S_{n+2}+\frac{1}{2}S_{n+1}+\frac{1}{6}S_{n}[/math]
With $n=1$, we then find:
$$a^4+b^4+c^4=S_4=3+\frac{1}{2}\cdot2+\frac{1}{6} \cdot1=\frac{25}{6}$$
For me, this is an ideal opportunity to use Newton's identities.
Let $x^3- px^2 +qx - r = 0$ be the equation whose roots are $a,\ b,\ c$, and let $S_k = a^k+b^k+c^k \ (k=1,2,3,4)$. Newton's identities say that
$\phantom{1}p = S_1 = 1$,
$2q = pS_1 - S_2 = 1-2 = -1$,
$3r = qS_1 - pS_2 + S_3 = -\frac12 -2 +3 = \frac12$,
$\phantom{1}0 = rS_1 - qS_2 + pS_3 - S_4$.​
Thus $p=1$, $q = -\frac12$, $r = \frac16$, and the cubic equation is $x^3 - x^2 - \frac12x - \frac16 = 0$. That is the same equation that Jester found for $a$, and as he pointed out it only has one real root. So $a,\ b,\ c$ cannot all be real.
Finally the last of those Newton's identities above shows that $S_4 = \frac16 + 1+ 3 = \frac{25}6$.
( i )using the result from MarkFL :
$a+b+c=1,\,\,ab+bc+ca=\dfrac {-1}{2},\,\, abc=\dfrac {1}{6}$
$(ab+bc+ca)^2=a^2b^2+b^2c^2+c^2a^2+2abc(a+b+c)=$$ \dfrac {1}{4}$
$\therefore a^2b^2+b^2c^2+c^2a^2=$$ \dfrac {1}{4} - 2abc(a+b+c)=\dfrac {1}{4} - \dfrac {1}{3}=\dfrac {-1}{12}<0$
This proves the first part :the simultaneous equationsno has no real solution
( ii )
$(2)^2:$$(a^2+b^2+c^2)^2=a^4+b^4+c^4+2(a^2b^2+b^2c^2+c^2a^2)=4$$\therefore a^4+b^4+c^4=4-2\times(\dfrac {-1}{12})=\dfrac {25}{6}$ #
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
