Solving for Stress and Strain in Three Dimensions
Similarly, the second equation can be rewritten as:\sigma_{yy}=\frac{2(\lambda+\mu)\sigma_{yy}+\lambda(\sigma_{xx}+\sigma_{zz})}{(3\lambda+2\mu)}And the third equation as:\sigma_{zz}=\frac{2(\lambda+\mu)\sigma_{zz}+\lambda(\sigma_{xx}+\sigma_{yy})}{(3\lambda+2\mu)}These equations are equivalent to the original set of 3 equations, but they are
KEØM
68
Knowing that the stress and strain for an isotropic media can be related with the following expressions:
[itex]\sigma_{xx} = (\lambda + 2\mu)\varepsilon_{xx} + \lambda\varepsilon_{yy} + \lambda\varepsilon_{zz}[/itex]
[itex]\sigma_{yy} = \lambda\varepsilon_{xx} + (\lambda + 2\mu)\varepsilon_{yy}) + \lambda\varepsilon_{zz}[/itex]
[itex]\sigma_{zz} =\varepsilon_{xx}\lambda+ \lambda\varepsilon_{yy} + (\lambda + 2\mu)\varepsilon_{zz}[/itex]
Solve this system of equations for the three strain components to derive that:
[itex]\varepsilon_{xx} = \frac{2(\lambda + \mu)\sigma_{xx} - \lambda(\sigma_{yy} + \sigma_{zz})}{2\mu(3\lambda + 2\mu)}[/itex]
[itex]\varepsilon_{yy} = \frac{2(\lambda + \mu)\sigma_{yy} - \lambda(\sigma_{xx} + \sigma_{zz})}{2\mu(3\lambda + 2\mu)}[/itex]
[itex]\varepsilon_{zz} = \frac{2(\lambda + \mu)\sigma_{xx} - \lambda(\sigma_{xx} + \sigma_{yy})}{2\mu(3\lambda + 2\mu)}[/itex]
[itex]\sigma_{xx} = (\lambda + 2\mu)(\varepsilon_{xx}) + \lambda\varepsilon_{yy} + \lambda\varepsilon_{zz}[/itex]
[itex]\sigma_{yy} = \lambda\varepsilon_{xx} + (\lambda + 2\mu)(\varepsilon_{yy}) + \lambda\varepsilon_{zz}[/itex]
[itex]\sigma_{zz} =(\varepsilon_{xx}) + \lambda\varepsilon_{yy} + (\lambda + 2\mu)\varepsilon_{zz}[/itex]
[itex]\sigma_{ij} = \lambda\delta{ij}\varepsilon_{kk} + 2\mu\varepsilon{ij}[/itex]
Hint: [itex] \sigma_{xx} = \sigma_{yy} [/itex] due to symmetry.
Well I put the three equations into matrix and tried to carry out row reduction and I came up with the following result:
[itex]
\left[
\begin{array}{c}
\sigma_{xx} \\
\sigma_{yy} \\
\sigma_{zz}
\end{array}
\right]
\left[
\begin{array}{ccc}
\lambda + 2\mu & \lambda & \lambda \\
\lambda & \lambda + 2\mu & \lambda \\
\lambda & \lambda & \lambda + 2\mu \\
\end{array}
\right]
\left[
\begin{array}{c}
\varepsilon_{xx} \\
\varepsilon_{yy} \\
\varepsilon_{zz}
\end{array}
\right]
[/itex]
I firstly attempted to remove the terms in the first column and the second and third rows, I did this by multiplying the top row by [itex]\frac{\lambda}{\lambda + 2\mu}[/itex] and subtracting that from the second and third rows which gave me the following matrix:
[itex]
= \left[
\begin{array}{ccc}
0 & \lambda + 2\mu - \frac{\lambda^2}{\lambda + 2\mu} & \lambda - \frac{\lambda^2}{\lambda + 2\mu} \\
0 & \lambda - \frac{\lambda^2}{\lambda + 2\mu} & \lambda + 2\mu - \frac{\lambda^2}{\lambda + 2\mu}
\end{array}
\right]
[/itex]
In order to get rid of the term in the second column and the third row, I multiplied the second row by [itex] \frac{\lambda(\lambda + 2\mu) - \lambda^2}{(\lambda + 2\mu)^2 - \lambda^2}[/itex] and subtracted that row from the third row. This gave me the following matrix:
[itex]
= \left[
\begin{array}{ccc}
0 & 0 & \frac{(\lambda(\lambda + 2\mu) - \lambda^2)^2}{(\lambda + 2\mu)((\lambda + 2\mu)^2 - \lambda^2)} - \left(\lambda + 2\mu - \frac{\lambda^2}{\lambda + 2\mu}\right)
\end{array}
\right]
[/itex]
Therefore I can write my first solution out as:
[itex] \sigma_{zz} = \left(\frac{(\lambda(\lambda + 2\mu) - \lambda^2)^2}{(\lambda + 2\mu)((\lambda + 2\mu)^2 - \lambda^2)} - \left(\lambda + 2\mu - \frac{\lambda^2}{\lambda + 2\mu}\right)\right)\varepsilon_{zz}[/itex]
which doesn't appear to be right. It would be of much help if someone could show me an easier method. Perhaps Kramer's Rule but I am unfamiliar with that method. Any help will be greatly appreciated.
Thank you,
KEØM
You haven't performed all the algebra you can on the coefficient of epsilon-zz. I would get a common denominator and add the two terms together to see if further simplification results.
Cramer's rule is fairly easy to remember. I am surprised you haven't com across it. It's the one where you compute all of the determinants and solve for the unknowns.
http://en.wikipedia.org/wiki/Cramer's_rule
Thank you for your help steamengine, I was able to solve the problem by finding the inverse matrix using the method of determinants and cofactors. Thanks again for your reply.
In your first attempt, you forgot to apply the operations to the left-hand sides of the equations. When you do something to the right hand side of an equation, you need to do the same thing to the left hand side.
For this particular set of 3 simultaneous linear equations, there is a simple trick for solving for the three strains. Just add the three equations together, to get:
[tex](\sigma_{xx}+\sigma_{yy}+\sigma_{zz})=(3\lambda+2\mu)(\epsilon_{xx}+\epsilon_{yy}+\epsilon_{zz})[/tex]
or
[tex](\epsilon_{xx}+\epsilon_{yy}+\epsilon_{zz})=\frac{(\sigma_{xx}+\sigma_{yy}+\sigma_{zz})}{(3\lambda+2\mu)}[/tex]
Then, rewrite the first equation as:
[tex]\sigma_{xx}=\lambda (\epsilon_{xx}+\epsilon_{yy}+\epsilon_{zz})+2\mu \epsilon_{xx}=\lambda \frac{(\sigma_{xx}+\sigma_{yy}+\sigma_{zz})}{(3\lambda+2\mu)}+2\mu \epsilon_{xx}[/tex]
UN
Dear KEØMUN,
Thank you for sharing your solution attempt and for seeking help. Your approach using row reduction is a valid method for solving this system of equations. However, it seems that there may have been a mistake in your calculations. Here is a step-by-step solution using Kramer's Rule to solve for the three strain components:
1. First, we need to rewrite the system of equations in the form of a matrix equation:
\left[
\begin{array}{c}
\sigma_{xx} \\
\sigma_{yy} \\
\sigma_{zz}
\end{array}
\right]
\left[
\begin{array}{ccc}
\end{array}
\right]
\left[
\begin{array}{c}
\varepsilon_{xx} \\
\varepsilon_{yy} \\
\varepsilon_{zz}
\end{array}
\right]
2. Now, we can use Kramer's Rule to solve for each strain component. For \varepsilon_{xx}, we replace the first column of the coefficient matrix with the vector of constants and solve for the determinant:
\varepsilon_{xx} = \frac{\left|
\begin{array}{ccc}
\sigma_{xx} & \lambda & \lambda \\
\sigma_{yy} & \lambda + 2\mu & \lambda \\
\sigma_{zz} & \lambda & \lambda + 2\mu \\
\end{array}
\right|}{\left|
\begin{array}{ccc}
\end{array}
\right|}
3. Expanding the determinant, we get:
\varepsilon_{xx} = \frac{\sigma_{xx}[(\lambda + 2\mu)^2 - \lambda^2] - \lambda\sigma_{yy}(\lambda + 2\mu - \lambda) + \lambda\sigma_{zz}(\lambda - \lambda)}{(\lambda +
FAQ: Solving for Stress and Strain in Three Dimensions
1. What is stress and strain in three dimensions?
Stress and strain in three dimensions refer to the measurement of how a material responds to external forces in three-dimensional space. It is important to consider all three dimensions (length, width, and depth) when analyzing the behavior of a material under stress.
2. Why is it important to solve for stress and strain in three dimensions?
Solving for stress and strain in three dimensions allows scientists and engineers to accurately predict the behavior of materials under various conditions. This information is crucial in designing structures and materials that can withstand external forces and stresses.
3. What factors affect stress and strain in three dimensions?
The main factors that affect stress and strain in three dimensions include the type of material, the magnitude and direction of external forces, and the geometry of the material. Other factors such as temperature, time, and environmental conditions may also play a role.
4. How is stress and strain in three dimensions measured?
Stress is typically measured in units of force per unit area, such as pounds per square inch (psi) or newtons per square meter (N/m2). Strain is measured as the change in length or deformation divided by the original length. The unit of strain is dimensionless, but it is often expressed as a percentage.
5. What are some common methods for solving stress and strain in three dimensions?
There are several methods for solving stress and strain in three dimensions, including analytical methods, numerical methods, and experimental methods. Analytical methods involve using equations and mathematical models to calculate stress and strain. Numerical methods use computer simulations to analyze stress and strain. Experimental methods involve conducting physical tests on materials to measure their response to external forces.
