Solving for the roots of unity of a complex number
In summary, the student attempted to solve a complex equation in polar form that required the use of a root of unity, but was not successful.
trap101
342
Find both square roots of the following number:
-15-8i
De Moivre's thm: rn(cos(n[itex]\sigma[/itex]) + i sin(n[itex]\sigma[/itex])
So to use De Moivre's I have to find the modulus and the argument.
actually in this question r = 1, what I'm left to have to try and figure out is how to obtain -15 - 8i
from (cos(n[itex]\sigma[/itex]) + i sin(n[itex]\sigma[/itex])
All I could think of possibly doing is setting Cos[itex]\sigma[/itex] = -15 and
iSin[itex]\sigma[/itex] = -8 but even doing that doesn't really provide me with much information. Unless that's what I'm suppose to work with.
##r\neq 1##, go back and compute ##|-15-8i|##. Your method should work once you use the correct value of ##r##.
Ok. Well before I had said the 1, the modulus I got was 17. Using that relation, then what I would end up doing is finding this relationship:
z2 = -15-8i but now I converted -15-8i into polar form:
z2 = 17(cos[itex]\sigma[/itex] + iSin[itex]\sigma[/itex])
now all that is left is for me to find the roots of unity of this equation.
Actually in the conversion to polar form, how would I write the relations:
i.e: Cos[itex]\sigma[/itex] = -15/17 ?
would it be as [itex]\sigma[/itex] = Cos-1(-15/17)?
You want to solve
$$z^2 = 17 ( \cos 2\sigma + i \sin 2\sigma).$$
A root of unity is something slightly different. Namely, a complex number of the form
$$w_k = \cos \frac{2\pi k}{n} + i \sin \frac{2\pi k}{n},~~k=0,1,\ldots, n-1$$
satisfies ##(w_k)^n = 1##. The ##w_k## are the nth roots of unity. What you want to do is take the square root of a complex number. The two concepts are related.
For the principal root you can indeed solve ##\cos 2\sigma = -15/17##. There is another root obtained by adding a multiple of ##i\pi## to ##\sigma##.
I can? This is where my rusty trig skills come to bite me:
Cos 2[itex]\sigma[/itex] = -15/17
How is this going to be anywhere near a clean solution of the form (pi/3) or something of the sort?
So what I'm doing is the same "process" as finding the roots of unity, but instead it is with respect to another value that is not 1?
I would do the calculation with a few significant figures. At the end, you should be able to look at the answer and figure out the exact result in whole numbers.
Yes. A root of unity is a solution to ##z^n =1##. Instead of ##1##, you have ##-15 - 8i##. The DeMoivre theorem is used in both cases.
If you are trying to find a square root using DeMoivre's theorem, n = 1/2 instead of n = 2.
From the statement of De Moivre's theorem, the OP set the problem up as "find ##z## if ##z^2 = -15-8i##." You can indeed set the problem up your way, but it could add an additional form of confusion to change the OP's notation.
Yeah I know the way he's talking about, but I found it more confusing when trying to find the rest of the trig relations. Thanks for the help.
The complex number, -15-8i, is in the third quadrant of the complex plane.
cos-1(-15/17) is in the second quadrant.
You can express [itex]\sigma[/itex] in several ways.
-cos-1(-15/17) is in the third quadrant. Add multiples of 2π to that.
Alternatively: ##\ \pi+\cos^{-1}(15/17)\ ## is in the third quadrant. Add multiples of ##\ 2\pi\ ## to that.
Related to Solving for the roots of unity of a complex number
1. What are the roots of unity of a complex number?
The roots of unity of a complex number are the solutions to the equation xn = 1, where x is a complex number and n is a positive integer. These solutions form a regular polygon when plotted on the complex plane.
2. How do you solve for the roots of unity of a complex number?
To solve for the roots of unity of a complex number, we use the formula x = cos(2kπ/n) + i*sin(2kπ/n), where k is an integer between 0 and n-1. This formula can be derived using De Moivre's theorem.
3. Why are the roots of unity important in complex analysis?
The roots of unity have significant applications in complex analysis, particularly in the study of periodic functions and polynomial equations. They also play a crucial role in understanding the behavior of complex numbers, such as rotation and symmetry.
4. How many roots of unity does a complex number have?
A complex number has n distinct roots of unity, where n is the degree of the complex number. For example, a complex number of degree 5 will have 5 distinct roots of unity.
5. Can complex numbers have imaginary roots of unity?
Yes, complex numbers can have imaginary roots of unity. These roots are represented by complex numbers with a real part of 0 and an imaginary part of ±i. For example, the imaginary roots of unity for a complex number of degree 4 are ±i.
