Solving for the Speed to Reach a Star 240 Light Years Away
MermaidWonders
112
How fast would you have to go to reach a star 240 light years away in an 85-year human lifetime?
Here, I know that I'm supposed to find $v$, but I'm having a hard time setting up my equation(s) in order to reach the final answer. :(
Mathematics news on Phys.org
Let's start with a question. You do know that you can go 85 light years in 85 years at 1x Speed of Light, right?
There is a wrinkle here. If we are talking about an observer on Earth then as tkhunny points out there must be some kind of misprint... It can't be done.
If you are talking about an observer on the flight we can do it. What do you know about time dilation? (See the section "Simple Inference of Velocity Time Dilation.")
Can you finish from here? If not just let us know.
-Dan
Yes.
-Dan
I know that the time measured in the frame in which the clock is at rest is called the proper time, and so a moving clock runs slower (hence dilated).
So what we have here is
\(\displaystyle \Delta t' = \frac{\Delta t}{\sqrt{1 - \frac{v^2}{c^2}}}\)
where \(\displaystyle \Delta t'\) is measured by the observer's clock and \(\displaystyle \Delta t\) is the time in the moving frame, aka "proper time."
So one possibility is if we wish the moving frame to experience 85 years and the observer's frame to be 240 years, then \(\displaystyle \Delta t' = 240\) and \(\displaystyle \Delta t = 85\). Solve for v.
-Dan
-Dan
But isn't the light year a unit of distance? For instance, the 240 light years in this question would represent a certain distance?
topsquark said:
You were talking about times in your original post, not distances.
-Dan
What do you mean? It says "240 light years away"... I'm confused.
Indeed, the distance traveled is $v\Delta t' = 240\text{ lightyear}$.
So we have $\Delta t' = \frac{240\text{ lightyear}}{v}$ and $\Delta t = 85\text{ year}$.
Ah, OK, that makes sense. So is $\Delta t'$ the time measured by the person on board the spaceship, and 85 years measured by a person at rest on Earth?
It's the other way around.
Oops, my bad. Thanks!
