MHB Solving for U & P in a Coordinate Change
  • Thread starter Thread starter avyunker
    Change Coordinate
To solve for U and P in the coordinate transformation z = U⋅x + P, two equations are established based on the given points: -13U + P = 12 and -7U + P = 6. By subtracting the second equation from the first, U can be determined as 3. Substituting U back into either equation allows for the calculation of P, resulting in P being 21. Additionally, to find the original coordinate corresponding to the new coordinate of 11, the equation can be rearranged to solve for x, yielding the original coordinate as -2. The discussion effectively demonstrates how to derive U, P, and the original coordinate using algebraic methods.
avyunker
Assume that you are given a coordinate change on a line which changes the coordinate x to a new coordinate z given by the formula z=U⋅x+P where U,P are real numbers with U non zero. If the new coordinate of the point -13 is 12 and the new coordinate of the point -7 is 6 then we must have U= ? and P= ? . Moreover, for the same transformation, if the new coordinate is (11) then the original coordinate must have been ?
Mathematics news on Phys.org
You can use the given information to set up a system of equations:
$$-13U+P=12$$
$$-7U+P=6$$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
