Solving For Unknown Vector Components
In summary, based on the given information of the plane's initial velocity, wind velocity, and final velocity and displacement, it is possible to determine the plane's initial velocity and angular displacement. Using the equations Pi*cosα = Pf - W*cosβ and Pi*sinα = W*sinβ, we can find Pi^2 and solve for Pi. In this specific problem, with a final velocity of 710 f/s and a displacement of 1.24°, the initial velocity is calculated to be approximately 649 f/s.
Badmachine
Is it possible to determine aircraft speed prior to contact with noted wind, if resulting aircraft speed, original aircraft heading, wind speed and wind direction and final aircraft heading are known?
P (plane): Bearing 241° (traveling approximately southwest) @ "X" f/s.
W (wind): Traveling south @ 32 f/s.
Plane and wind components represented by ordered pairs:
P = ["X" f/s cos(241°), "X" f/s sin(241°)] = ?, ?
W = [-32 f/s cos(90°), -32 f/s sin(90°)] = 0, -32
? + 0 = ?
? + (-32) = ?
||P + W|| = ?² + ?² = ?^(1/2) = 710 f/s
tan −1(?/?) = 62.24° + 180° = 242.24°
Displacement = 242.24° - 241° = 1.24°
Select a co-ordinate axis so that final direction of the plane (Pf) is along -x-axis.
Let the angle of the initial direction of the plane (Pi) with he new x-axis be α.
Let the angle of the direction of the wind (W) with he new x-axis be β. From the given data you can find β.
Now sum of the x-components of Pi and W is equal to Pf.
And y component of Pi is equal and opposite to y-component of W.
Write the equations and solve.
Does the solution require eliminating the wind components or inverting the wind compinent's values?
The two equations become
(Pi)x + (W)x = (Pf) ...(1)
(Pi)y + (W)y = 0...(2)
Rearrange the equations.
(Pi)x = - (W)x + (Pf) ...(3)
(Pi)y = -(W)y ...(4)
Square eq. 3 and 4 and add to get (Pi)
Thanks rl. Let's see if I am following you correctly.
(Pi)y = -(W)y
(Pi)x = - (0)x + (P[710 f/s]f)
(Pi)y = -(32)y
710² + 32² = 505,124^(1/2) = 710.72
Apparently I'm performing the calculations incorrectly, as Pi = 683 f/s (value omitted in original post).
Original problem:
P (plane): Bearing 241° (traveling approximately southwest) @ 683 f/s (465 mph); W (wind): traveling south @ 32 f/s (22 mph)
[683 f/s cos(241°), 683 f/s sin(241°)] = -331, -597
-331 + 0 = -331
-597 + (-32) = -629
||P + W|| = 331² + 629² = 505, 2021/2 = 710 f/s
tan −1(629/331) = 62.24° + 180° = 242.24°
What is required in the original problem?
For example, if the want to cross a river and reach the opposite bank, you have to row in the upstream direction. Similarly which velocity is given in the problem?
To determine the final aircraft velocity (Pf) and angular aircraft displacement from original heading, after application of a given wind.
Had hoped to learn how to "reverse engineer" for the original aircraft speed (Pi) or even heading simply based on other knowns.
OK. It can be done in the following way. Refer my post#2 and #4
Pi*cosα + W*cosβ = Pf Or
Pi*sinα = W*sinβ
Pi^2 = ( Pf - W*cosβ )^2 + (W*sinβ)^2
In the given problem, if the velocity of plane is Pf, then β = 270degrees - 241 degrees.
So using the above equation you can find Pi.
Thanks rl.
Perhaps I miscalculated somehwere, but at this stage I arrive at Pi = 649 f/s (as opposed to 683 f/s)
β = 270degrees - 241 degrees = 29
Pi^2 = [710 - (-32)*cos29]^2 + [(-32)*sin29)]^2
421,400 = 421,159 + 241
649 f/s
FAQ: Solving For Unknown Vector Components
What is the process for solving for unknown vector components?
The process for solving for unknown vector components involves breaking down the vector into its x and y components, using trigonometric functions to find the magnitude and direction of each component, and then combining the components to find the overall magnitude and direction of the vector.
How do you determine the magnitude of a vector component?
The magnitude of a vector component can be determined by using the Pythagorean theorem, which states that the square of the hypotenuse of a right triangle is equal to the sum of the squares of the other two sides. In this case, the hypotenuse would be the magnitude of the vector, and the other two sides would be the x and y components.
What is the difference between a scalar and a vector quantity?
A scalar quantity is a measurement that only has magnitude, while a vector quantity has both magnitude and direction. Examples of scalar quantities include temperature and time, while examples of vector quantities include displacement and velocity.
How do you find the direction of a vector component?
The direction of a vector component can be found by using the inverse tangent function (arctan) to calculate the angle between the component and the x-axis. This angle is also known as the direction angle.
Can you use the same method to solve for unknown vector components in three-dimensional space?
Yes, the same method can be used to solve for unknown vector components in three-dimensional space. In addition to finding the x and y components, you would also need to find the z component and use the Pythagorean theorem in three dimensions to calculate the magnitude of the vector.
