MHB Solving for x: Clearing Fractions or Finding Common Denominator?
  • Thread starter Thread starter Dethrone
    Fractions
The discussion focuses on solving inequalities and equations involving fractions, specifically the inequality $$\frac{x-2}{x-5}>\frac{x-3}{x-4}$$ and the equation $$\frac{1}{x-2}=\frac{3}{x+2}-\frac{6x}{(x+2)(x-2)}$$. Participants emphasize the importance of finding a common denominator to avoid sign changes that can lead to incorrect solutions. The consensus is that while clearing fractions can be quicker, it introduces potential extraneous solutions that must be checked. Ultimately, the safest approach is to manipulate the expressions carefully to maintain the integrity of the solutions.
Dethrone
Given:
How I would normally solve it is to bring everything over to one side and find a common denominator. The answer of which is $x>5$
Now a commentary on this question says to "watch out" for sign changes if you multiply both sides by an expression, so I decided to try it out:
If $x>4$:
$$\frac{(x-2)(x-4)}{x-5}>x-3$$
If $x>5$ and $x>4$:
$$(x-2)(x-4)>(x-3)(x-5)$$
Solving gives us $x>5$, which is the same as above.
Question: Is it just a lucky coincidence that the restriction I applied on the second step $x>4$ just HAPPENED to SATISFY our answer, or could the answer have been say $x<3$ and dividing both sides would have eliminated that solution?
Question 2:
To begin this problem, would you attempt to "clear the fraction" by multiplying by (x-2)(x+2)? I always get paranoid about doing it, because it introduces the solution $x=\pm 2$, which you will then have to replug back into the original equation to confirm, right?
Would attempting to find a common denominator and bring everything to one side be a smarter approach? Or should just clearing the fraction, which is much faster, be preferred? It's just that the latter requires that you resubstitute back into the original equation, whereas the former doesn't require resubstitution. Thoughts?
Mathematics news on Phys.org
Rido12 said:
Given:
If $x>4$:
If $x>5$ and $x>4$:
What You're saying is true in part. Assuming x <4 the inequality is verified for $\frac{7}{2} < x <4$ ...
Kind regards
$\chi$ $\sigma$
Rido12 said:
Given:
I think that this is definitely the safest strategy. In this case, you would get $$\frac{x-2}{x-5} - \frac{x-3}{x-4} > 0,$$ $$\frac{(x-2)(x-4) - (x-3)(x-5)}{(x-4)(x-5)} > 0,$$ $$\frac{2x-7}{(x-4)(x-5)} > 0.$$ That expression changes sign when any of the linear factors in the numerator or denominator changes sign, telling you that the critical points are when $x = \frac72,\ 4,\ 5$ (as chisigma has pointed out).
Rido12 said:
Question 2:
This is an equation rather than an inequality, so in this case there is nothing to be lost by multiplying by $(x-2)(x+2)$ (except that you have to remember that $x=\pm 2$ cannot be solutions).
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
