Solving for x: Four Positive Real Numbers
In summary, the given conversation discusses finding a solution for $x$ given the equations $a+\dfrac{1}{b}=b+\dfrac{1}{c}=c+\dfrac{1}{d}=d+\dfrac{1}{a}=x$, where $a,b,c,d$ are different positive real numbers. The solution is found by using a function $f(s) = \dfrac1{x-s}$ and finding points of order $4$ for this function. The only possible solution for $x$ is $\sqrt2$ and it is not possible to choose all four numbers to be positive.
anemone
MHB
POTW Director
3,883
115
Let $a,\,b,\,c,\,d$ be different positive real numbers such that $a+\dfrac{1}{b}=b+\dfrac{1}{c}=c+\dfrac{1}{d}=d+\dfrac{1}{a}=x$.
Find $x$.
Mathematics news on Phys.org
Find $x$.
$4x=a+\dfrac{1}{a}+b+\dfrac{1}{b}+c+\dfrac{1}{c}+d+\dfrac{1}{d}$
using $AP\geq GP$
we have :$4x\geq 8$
$\therefore x\geq 2$
using $AP\geq GP$
we have :$4x\geq 8$
Thanks for participating, Albert...
But, I'm sorry, your answer that states that $x\geq 2$ isn't conclusive enough and it's wrong. Also, $x=2$ is certainly not a solution for the given original equation.:(
For your information, $x=\sqrt{2}$ is the answer to this problem.
sorry I did not notice $a,b,c,d$ are different
Find $x$.
[sp]Let $f(s) = \dfrac1{x-s},$ and define a sequence of functions $f^{(n)}$ inductively by $f^{(n+1)}(s) = f\bigl(f^{(n)}(s)\bigr),$ with $f^{(1)}(s) = f(s).$ Then $\dfrac1{f(s)} = x-s,$ so that $s + \dfrac1{f(s)} = x.$ Thus if $s=a$ then $f(s) = b$, $f^{(2)}(s) = c$, $f^{(3)}(s) = d$ and $f^{(4)}(s) = a = s.$ So we are looking for points of order $4$ for $f$ (that is to say, fixed points for the function $f^{(4)}$).
Start with $f^{(2)}(s) = f\bigl(f(s)\bigr) = \dfrac1{x-\frac1{x-s}} = \dfrac{x-s}{x^2-1-sx}.$ Then $$f^{(4)}(s) = f^{(2)}\bigl(f^{(2)}(s)\bigr) = \frac{x - \frac{x-s}{x^2-1-sx}}{x^2-1 - \frac{x(x-s)}{x^2-1-sx}} = \frac{x^3 - sx^2 - 2x + s}{x^4 - sx^3 - 3x^2 + 2xs + 1}.$$ The condition $f^{(4)}(s) = s$ becomes $x^3 - sx^2 - 2x + s = s(x^4 - sx^3 - 3x^2 + 2xs + 1),$ which simplifies to $x(2-x^2)(s^2 - sx + 1) = 0.$
If $x=0$ then $f(s) = -\dfrac1s$, and $f^{(2)}(s) = s$, so that every point has order $2$. If $s^2 - sx + 1 = 0$ then $s = \dfrac1{x-s}$, so that $s$ is a fixed point of $f$, which is not what we want. So the only possibility to find points of order $4$ is if $2-x^2 = 0$, in other words $x = \pm\sqrt2$.
The question asks for all the numbers $a,b,c,d$ to be positive, so we must take $x=\sqrt2.$ The function $f(s) = \dfrac1{\sqrt2-s}$ satisfies $f^{(4)}(s) = s$ for all $s$. It also has the property $f(s) > s$ whenever $s<\sqrt2$; and $f(s)<0$ whenever $s>\sqrt2$. That means that it is never possible to choose all four numbers $a,b,c,d$ to be positive. So long as you allow them to take negative values, you can choose $a$ to be any real number except $0$, $\frac1{\sqrt2}$ or $\sqrt2$. Then the numbers $a$, $b = f(a)$, $c = f(b) = f^{(2)}(a)$ and $d = f( c) = f^{(3)}(a)$ will be distinct, and will satisfy the given equations. But one of those numbers will necessarily be negative: you can't have all four of them positive.[/sp]
The question asks for all the numbers $a,b,c,d$ to be positive, so we must take $x=\sqrt2.$ The function $f(s) = \dfrac1{\sqrt2-s}$ satisfies $f^{(4)}(s) = s$ for all $s$. It also has the property $f(s) > s$ whenever $s<\sqrt2$; and $f(s)<0$ whenever $s>\sqrt2$. That means that it is never possible to choose all four numbers $a,b,c,d$ to be positive. So long as you allow them to take negative values, you can choose $a$ to be any real number except $\sqrt2$. Then the numbers $a$, $b = f(a)$, $c = f(b) = f^{(2)}(a)$ and $d = f( c) = f^{(3)}(a)$ will be distinct, and will satisfy the given conditions. But you can't have all four of them positive.[/sp]
Awesome, Opalg! :D And thanks for participating!
Here is another method:
Expressing $a,\,b,\,c,\,d$ in terms of $x$ and $a$, we have
$d=\dfrac{ax-1}{a},\,c=\dfrac{ax^2-x-a}{ax-1},\,b=\dfrac{ax^3-x^2-2ax+1}{ax^2-x-a}$
Substitute the last expression into $a+\dfrac{1}{b}=x$, we have
$a+\dfrac{ax^2-x-a}{ax^3-x^2-2ax+1}=x$
$ax^4-a^2x^3-x^3-2ax^2+2a^2x+2x=0$
$x(x^2-2)(ax-a^2-1)=0$
Note that the last factor on the LHS of the last row is non-zero, for otherwise we get
$a+\dfrac{1}{a}=x=a+\dfrac{1}{b}$, which contradicts the fact that $a\ne b$. Since $x>0$, we must have $x=\sqrt{2}$.
Edit: Opalg is right, this problem is flawed since it is impossible to choose all four positive numbers that satisfy the given condition. Thanks, Opalg for this discovery.
Find $x$.
I have a question ,you said $x=\sqrt 2$
but by using $AP>GP$ (FOR $a,b,c,d$ are different and positive real numbers)
$4x=a+b+c+d+\dfrac{1}{a}+\dfrac{1}{b}+\dfrac{1}{c}+\dfrac{1}{d}>8\sqrt[8]{abcd\times \dfrac{1}{abcd}}=8$
so $x>2>\sqrt 2$
how to explain it ? do I miss something ?
so $x>2>\sqrt 2$
Hi again Albert!:)
Opalg has mentioned about the flaw of this problem in his solution and your intuition is right, this problem will work with three positive different real and the fourth will necessarily be a negative real.:)
my solution:
let $b=\sqrt m+\sqrt {m-1}>0$
then $\dfrac {1}{b}=\sqrt m -\sqrt{m-1}>0$
for simplification let $b=\dfrac {1}{b}$
then $b=m=1---(1)$
and :$a=x-1>0 ---(2)$ so $x>1$
$c=\dfrac {1}{x-1}>0---(3)$
$d=\dfrac {x^2-x-1}{x-1}<0---(4)$
for $c+\dfrac {1}{d}=x$
we have :$\dfrac {1}{x-1}+\dfrac {x-1}{x^2-x-1}=x$
or $(x-1)^2=(x^2-x-1)^2$
we get :$x-1=\pm (x^2-x-1)$
and $x=0,2,\sqrt 2$
if $x=2$ then $a=b=c=d=1$
and $x=\sqrt 2$ is the solution we want
FAQ: Solving for x: Four Positive Real Numbers
How do I solve for x in an equation with four positive real numbers?
To solve for x in an equation with four positive real numbers, you can use algebraic techniques such as combining like terms, factoring, and isolating x on one side of the equation.
What is the purpose of solving for x in an equation with four positive real numbers?
The purpose of solving for x in an equation with four positive real numbers is to find the value of x that makes the equation true. This can help in solving problems and making calculations in various fields such as science, engineering, and mathematics.
Can there be multiple solutions when solving for x in an equation with four positive real numbers?
Yes, there can be multiple solutions when solving for x in an equation with four positive real numbers. This means that there can be more than one value of x that makes the equation true.
Is it possible to have no solution when solving for x in an equation with four positive real numbers?
Yes, it is possible to have no solution when solving for x in an equation with four positive real numbers. This means that there is no value of x that makes the equation true.
What are some common mistakes to avoid when solving for x in an equation with four positive real numbers?
Some common mistakes to avoid when solving for x in an equation with four positive real numbers include forgetting to distribute or combine like terms, making errors in factoring, and not checking the solution to see if it makes the original equation true.
