Solving for x: sqrt(x+3)-2/4x-4 & 1-sqrt(cosx)/x^2
  • MHB
  • Thread starter aniel
In summary: The numerator is expressing how many more things there are after x equals 1. It is equal to the square of the amount that x gets incremented by (x+3). This is because the numerator is the product of the two terms on the left-hand side. The denominator is the product of the two terms on the right-hand side. The numerator is larger because it is expressing the magnitude of the increase, while the denominator is expressing how many there are in total.Here's the second one.\frac{1-\sqrt{\cos{x}}}{x^2}Rationalize the denominator:\frac{1-\sq
aniel
the first one: sqrt(x + 3) - 2 / 4x -4
the second one : 1 - sqrt(cosx) / x^2
thnk you
Hi aniel, :)
Welcome to Math Help Boards!
Is the first limit this? \(\displaystyle \frac{\sqrt{x+3}-2}{4x-4}\)?
Is the second one this? \(\displaystyle \frac{1-\sqrt{\cos{x}}}{x^2}\)?
The other thing is limits must have x approach some value, so we can't do anything with these two problems until we know that. You'll usually see something like \(\displaystyle \lim_{x \rightarrow 3}\).
Im sorry i forgot where the x tends to go :/
lim (x-> 1) sqrt (x+3) - 2 /4x - 4
lim (x->0) 1- sqrt (cosx) / x^2
and I am so sorry taking your time but i get so confused with limits .
Don't be sorry at all :) This site was created so anyone can get free math help.
Ok, next question. Have you covered L'Hôpital's rule in your calculus class? Both limits end up being 0/0 and that is a special case where we can use a time saving shortcut.
Welll thank you sir :)
Yes we used the hospital rule and well i did some shortcuts at both of them but the book solution it doesn't coincides with my solution.
well i went till here to both of them
lim (x-> 1) sqrt (x+3) - 2 /4x - 4 = §
lim (x->1) [sqrt( (x+3) -2] *
[sqrt( (x+3) +2]/ (4x-4) *sqrt( (x+3) +2 =
lim (x->1) x+3-4 /4x-4 [
sqrt( (x+3) +2]
and to the second one:
ilm (x->0) 1- sqrt (cosx) / x^2
=lim (x->0) [1- sqrt (cosx)]*[1+ sqrt (cosx)] / x^2 * [sqrt(cosx)
=lim (x->0) sin^2x /[1 + sqrt(cosx)] *x^2
You're doing them "the long way", which is fine just longer. I'll do the first one the way you started it though to get the answer :)
\(\displaystyle \lim_{x \rightarrow 1} \frac{\sqrt{x+3}-2}{4x-4} = \frac{\sqrt{x+3}-2}{4x-4} \cdot \frac{\sqrt{x+3}+2}{\sqrt{x+3}+2}=\frac{x-1}{(4x-4)(\sqrt{x+3}+2)}\)
That's pretty much what you got to and is correct thus far. The "trick" here is seeing that \(\displaystyle 4x-4=4(x-1)\). This will allow us to make a nice cancellation.
\(\displaystyle \frac{x-1}{(4x-4)(\sqrt{x+3}+2)}=\frac{x-1}{4(x-1)(\sqrt{x+3}+2)}=\frac{1}{(4)(\sqrt{x+3}+2)}\)
I haven't checked this solution, but I'm hoping that it's 1/16, which is what you get if you now direct substitute.
Than you sir yes i solved it and it is 1/16
my mistake its that i did in this way 4(x - 4/x) :/
I get the same result using L'Hôpital's rule:
$\displaystyle \lim_{x\to1}\frac{\sqrt{x+3}-2}{4x-4}=\lim_{x\to1}\frac{\frac{1}{2\sqrt{x+3}}}{4}= \frac{1}{16}$
It happens. We all make mistakes like this. Just have to learn from them. You are doing really well though because you knew that you would have to cancel something in order to solve the problem, which is the key idea with these "indeterminate forms". Someone else is replying to this thread now, so I'll won't comment on #2 yet.
Once again, welcome to MHB! I hope you stick around and participate in our community.
Well I am really thankfull sir...its my pleasure to be part of this group, i hope i can learn more now and on.
Congratulations about ur job here.Its a great thing .
Thank you again !
Have you had any success with the second limit? Applying L'Hôpital's rule twice works nicely. :)
Hello, aniel!
Here's the first one.
[tex]\lim_{x\to1}\frac{\sqrt{x + 3} - 2}{4x -4 }[/tex]
Rationalize the numerator:
[tex]\frac{\sqrt{x+3} - 2}{4x-4}\cdot\frac{\sqrt{x+3}+2}{\sqrt{x+3}+2} \;=\; \frac{(x+3) - 4}{(4x-4)(\sqrt{x+3}+2)} [/tex]
. . .[tex]=\;\frac{x-1}{4(x-1)(\sqrt{x+3}+2)} \;=\;\frac{1}{4(\sqrt{x+3}+2)} [/tex]Therefore: .[tex]\lim_{x\to1}\frac{1}{4(\sqrt{x+3}+2)} \;=\;\frac{1}{4(\sqrt{4}+2)} \;=\;\frac{1}{4(2+2)} \;=\;\frac{1}{16}[/tex]
FAQ: Solving for x: sqrt(x+3)-2/4x-4 & 1-sqrt(cosx)/x^2
What is the purpose of solving for x in this equation?
The purpose of solving for x in this equation is to find the value or values of x that make the equation true. This can help us solve problems or understand the behavior of certain functions.
How do I isolate the variable x in this equation?
To isolate the variable x, you can use algebraic techniques such as distributing, combining like terms, and using inverse operations. In this case, you may need to use the quadratic formula or other methods to solve for x.
Is there a specific method for solving equations involving square roots?
Yes, there are specific methods for solving equations involving square roots. One method is to isolate the square root term and then square both sides of the equation to eliminate the square root. However, it's important to check your solutions to make sure they are valid for the original equation since squaring both sides can sometimes introduce extraneous solutions.
Can I use a calculator to solve this equation?
Yes, you can use a calculator to solve this equation. Many scientific or graphing calculators have a function to solve equations numerically, and you can also use the calculator to check your solutions.
What are the potential solutions to this equation?
The potential solutions to this equation will depend on the specific values of x that make the equation true. In general, there may be one or more real or complex solutions, or there may be no solutions at all. It's important to carefully solve the equation and check your solutions to ensure they are valid.
