Solving GR 2-Body Problem with Summ. of Christoffel Symbols
In summary: As we have discussed, GR does have solutions in the sense of being a well-posed initial value problem. But those solutions do not lend themselves to closed-form equations that can be added together to describe multiple bodies. In summary, attempting to approach the GR two body problem through summations of multiple Schwarzschild solutions is not a viable approach because the Einstein Field Equation is nonlinear and the curvatures do not add up. However, this does not mean that GR is not a valid theory or that we do not have a good understanding of how it works. It simply means that the solutions to complex systems cannot be expressed in simple, closed-form equations.
D.S.Beyer
50
TL;DR Summary
Can you approach the GR two body problem through summations of multiple Schwarzschild solutions?
Specifically, by using the Schwarzschild metric for each body of mass, then adding the Christoffel symbols together, to arrive at a new geodesic equation.
Take point C between bodies A and B.
Solve the Schwarzschild metric for both A and B.
In relation to body A, point C has specific Christoffel symbols.
Similarly, in relation to body B, point C has different Christoffel symbols.
Before the geodesics are constructed, can you add these vectors together?
To get the average Christoffel symbols, and then use that to construct the geodesic?
Would such a geodesic help model the two body problem?
Or, and this is the most likely, is it worthless?
NOTE : I’m not a math guy (clearly) but I’m really enjoying thinking about and getting into the math. Thank you for your patience.
No, because the Einstein Field Equation is nonlinear, so adding together two solutions does not give another solution.
Likes vanhees71, martinbn, Dale and 1 other person
D.S.Beyer said:
Summary:: Can you approach the GR two body problem through summations of multiple Schwarzschild solutions?
As @PeterDonis said this approach will not work for general relativity. It would work for electromagnetism. The difference is that Maxwell’s equations are linear and Einstein’s field equation is not.
It is possible to write a linear approximation to GR. As with any approximation it will fail when its assumptions are violated.
Likes vanhees71 and etotheipi
To add to Peter's answer: the curvatures don't add up. Basically, this is because schematically,
[tex]
R \sim (\Gamma + \partial\Gamma)^2
[/tex]
And as you probably know, even if you're not a math guy,
[tex]
R \sim (\Gamma + \partial\Gamma)^2 = (\Gamma)^2 + ( \partial\Gamma)^2 + 2 \Gamma \partial\Gamma
[/tex]
That last term ##2 \Gamma \partial\Gamma## spoils the linearity. It means that the curvature of black hole A plus the curvature of black hole B is not simply the sum of curvatures:[tex]
R_A + R_B \sim (\Gamma_A + \partial\Gamma_A)^2 + (\Gamma_B + \partial\Gamma_B )^2 \neq (\Gamma_A + \Gamma_B + \partial\Gamma_B + \partial\Gamma_B)^2 = R_{A+B}
[/tex]
Physically, the cross-terms can be interpreted as the self-interaction of the gravitational field. It's like two competing companies: if you put them next to each-other, they will compete, and as such their prices will be influenced by each-other, and hence different from the situation when they would be far apart, just doing their own business and asking the maximum prices their customers are happy to pay.
Likes vanhees71 and Dale
[tex]
[/tex]
[tex]
[/tex]
[/tex]
Thank you. This small bit of math is helping a lot.
Sorry I tagged this as 'intermediate' when it was clearly 'beginner'
Actually it's still "I" because of the subject matter, which is at least undergraduate level, not high school.
Likes vanhees71
A more interesting question I would have asked. Is the pure gravitational 2-body problem in GR fully solvable? As far as I know the answer is "no".
Likes vanhees71
That is my understanding as well.
Likes vanhees71
That is, really, kinda mind blowing. I always assumed GR dealt with everything at the same time.
In some magical way. But really it can't even solve 2 bodies interacting.
It's still totally amazing, and I'm learning more everyday.
But this really makes me feel like we still don't really know how anything works for sure.
I'm getting a 'The more you know, the less you understand' vibe right now.
Thanks everyone for input. I feel like this thread can be closed.
It can, but numerically rather than analytically.
Likes vanhees71
It does. It's just that, except for very simple, highly symmetric situations, its solutions can't be expressed as closed form equations. But as @Dale points out, you can still solve any situation numerically. That is how two-body solutions are done in practice--for example, in analyzing systems like binary pulsars or merging black holes, in order to compare model predictions with observations.
Likes martinbn
GR has been proven to have solutions, in that it's been shown, mathematically, to be a well-posed initial value problem. Wald discusses this in "General Relativity" if you want the details. Actually finding the solutions though isn't easy.
Likes vanhees71 and martinbn
It's probably worth clarifying that the words "solvable" and "solution" have two different possible meanings in this context: they can mean "there are known solutions that can be expressed in closed-form equations", or they can just mean "there is a well-posed initial value problem, so you can generate a solution numerically from valid initial data even if you can't express it in closed-form equations".
The key point for the original OP question is that, since the Einstein Field Equation is nonlinear, you can't add two valid "solutions" in either of the above senses to get another valid solution.
Likes vanhees71
Related to Solving GR 2-Body Problem with Summ. of Christoffel Symbols
1. What is the GR 2-Body Problem?
The GR 2-Body Problem refers to the problem of finding the motion of two massive objects under the influence of gravity, using Einstein's theory of General Relativity (GR).
2. What is the Summation of Christoffel Symbols?
The Summation of Christoffel Symbols is a mathematical tool used in GR to calculate the curvature of spacetime. It involves summing certain components of the metric tensor, which represents the curvature of spacetime.
3. How is the GR 2-Body Problem solved using Summation of Christoffel Symbols?
The GR 2-Body Problem is solved by first calculating the Christoffel symbols for the given metric tensor, which represents the curvature of spacetime. These symbols are then used to calculate the equations of motion for the two objects, taking into account the effects of gravity.
4. What are the limitations of using Summation of Christoffel Symbols to solve the GR 2-Body Problem?
One limitation is that it assumes the two objects are point masses, which may not accurately represent real-world scenarios. Additionally, it does not take into account other factors such as the rotation of the objects or the presence of other massive objects in the vicinity.
5. How does solving the GR 2-Body Problem with Summation of Christoffel Symbols contribute to our understanding of gravity and spacetime?
By using the tools of GR to solve the 2-Body Problem, we gain a deeper understanding of how gravity affects the motion of massive objects in the universe. It also allows us to test and validate the predictions of Einstein's theory of General Relativity.
  • Differential Geometry
