Solving Heat PDEs: Is There a Standard Procedure?
  • MHB
  • Thread starter Markov2
  • Tags
    Heat Pdes
In summary, we can use the method of eigenfunction expansion to solve the partial differential equations in both scenarios. By separating variables and using conditions to solve for the eigenvalues and eigenfunctions, we can then use Fourier analysis to find the coefficients and ultimately obtain the solutions in terms of trigonometric functions. For the ODE, we can solve it in general by using basic ODE solving techniques.
Markov2
149
1) Solve
$\begin{aligned}
{u_t} &= K{u_{xx}},{\text{ }}0 < x < L,{\text{ }}t > 0, \\
u(0,t) &= 0,{\text{ }}u(L,t) = 0,{\text{ for }}t > 0, \\
u(x,0) &= 6\sin \frac{{3\pi x}}{L}.
\end{aligned} $
2) Solve
$\begin{aligned}
{u_t} &= 4{u_{xx}},{\text{ }}0 < x < 1,{\text{ }}t > 0, \\
u(0,t) &= 0,{\text{ }}u(1,t) = 0,{\text{ for }}t > 0, \\
u(x,0) &= x^2(1-x),\text{ for }x\in[0,1].
\end{aligned}$
Is there a standard procedure to solve this?
You can use the method of eigenfunction expansion.
Your solutions will be of the form $\sum a_ne^{-\lambda_nkt}\varphi_n(x)$
What's that method? Could you show me how to make the first one?
$u(x,t)=\varphi(x)T(t)$
$u_{xx}=\varphi'' T$
$u_{t}=\varphi T'$
Substitution: $\varphi T'=K\varphi'' T$
Separation of variables $\dfrac{\varphi''}{\varphi}=\dfrac{T'}{TK}=-\lambda$
Then we have $\dfrac{\varphi''}{\varphi}=-\lambda \Rightarrow \varphi''+\lambda\varphi=0 \Rightarrow \varphi(x)=C_1\cos\left(x\sqrt{\lambda}\right)+C_2\sin\left(x\sqrt{\lambda}\right)$
Now we have to solve
$\varphi_1(0) = 1$ and $\varphi_1'(0) = 0$
$\varphi_2(0) = 0$ and $\varphi_2'(0) = 1$
Doing so yields $\varphi(x)=A\cos\left(x\sqrt{\lambda}\right)+ \dfrac{ B\sin\left(x\sqrt{ \lambda }\right) }{ \sqrt{\lambda} }$
Use conditions
$u(0,t) = A = 0$
$\varphi(x)= \dfrac{B\sin\left(x\sqrt{ \lambda }\right)}{\sqrt{ \lambda }}$
$u(L,t) = \dfrac{ B\sin\left(L\sqrt{\lambda}\right) }{\sqrt{ \lambda }} = 0\Rightarrow \sin\left(L\sqrt{\lambda}\right) =0$
$\lambda_n=\left(\dfrac{\pi n}{L}\right)^2$
$\varphi_n(x)=\dfrac{L}{\pi n}\sin\left(\dfrac{x\pi n}{L}\right)$
Now you can solve for $\dfrac{T'}{KT}= - \lambda$.
Then use Fourier Analysis to find the coefficient $a_n$.
Then you will have $u(x,t) = \sum a_n \varphi(x)T(t)$
Evaluate $\sin(x+yi)$ against your eigenvalue to determine if you have complex solutions or not.
Thanks a lot!
What's the formula for this?
Markov said:
Thanks a lot!
\int_0^Lf(x)\sin\left(\frac{x\pi n}{L}\right)dx = \sum_{n=1}^{\infty}a_n\int_0^L\sin\left(\frac{n\pi x}{L}\right)\sin\left(\frac{m\pi x}{L}\right)dx
Every time on the RHS is zero except for when n = m because you have an orthogonal system on an interval.
$u(x,0) = f(x)$
Okay, on this part, do I need to get the solution in terms of trigonometric functions as the other equation you solved?
That is just an simply ODE. How would you solve it in general?
FAQ: Solving Heat PDEs: Is There a Standard Procedure?
What is a heat PDE?
A heat PDE (partial differential equation) is a mathematical equation that describes how temperature changes over time in a given system. It is often used in physics and engineering to model heat transfer in various materials and systems.
What is the standard procedure for solving heat PDEs?
The standard procedure for solving heat PDEs involves using known boundary conditions and initial conditions to transform the PDE into a simpler form, such as a series of ordinary differential equations. These equations can then be solved using numerical methods or analytical techniques.
How are heat PDEs used in real-world applications?
Heat PDEs are used in a variety of real-world applications, including modeling heat transfer in buildings, predicting the spread of wildfires, and designing efficient cooling systems for electronic devices. They are also used in materials science to study how heat affects the properties of different materials.
What are the limitations of solving heat PDEs?
One limitation of solving heat PDEs is that they often require simplifying assumptions, which may not accurately reflect real-world conditions. Additionally, the computational cost of solving PDEs can be high, making it difficult to analyze complex systems with many variables.
Can heat PDEs be solved analytically or do they require numerical methods?
Some simple heat PDEs can be solved analytically using mathematical techniques such as separation of variables or Fourier series. However, most real-world heat PDEs require numerical methods to obtain a solution, as they involve complex systems with multiple variables and boundary conditions.
