Solving how many square inches within a flag
  • MHB
  • Thread starter wtam1100
  • Tags
    Square
In summary, the conversation is about solving for the area of a white stripe on a flag, which is a parallelogram with a base and height. The suggested method is to calculate the product of the base and height, which equals 612 square inches in this case. A diagram is also mentioned as a helpful tool for solving the problem.
wtam1100
Hello all. I'm new here. Trying to help my daughter with her homework but I can't solve this problem wondering if there is any out there that is willing to help. Thanks a Head of time.
Mathematics news on Phys.org
Re: Solving how many square inches with in a flag
The white stripe is a parallelogram, whose area is found by computing the product of the base and the height. Can your daughter identify the measures of the base and height?
Yeah I think you are right. I'm just going with the 72 x 8.5. thanks for you input.
Yes, that's correct! (Star)
Hi,
I think a diagram is helpful:
the white area is essentially a parallelogram
to calculate the area of a parallelogram
A = base x height
A = 8.5 x 72 = 612 square inches
FAQ: Solving how many square inches within a flag
What is the formula for finding the area of a flag in square inches?
The formula for finding the area of a rectangle, which can be used for calculating the area of a flag, is length x width. Therefore, to find the area of a flag in square inches, you would multiply the length and width of the flag in inches.
How do you measure the length and width of a flag in inches?
To measure the length and width of a flag in inches, you would use a ruler or measuring tape. Place the ruler or measuring tape along one side of the flag and measure the distance in inches.
Can the area of a flag be calculated if it is not a rectangle?
Yes, the area of a flag can still be calculated if it is not a rectangle. You would need to divide the flag into smaller, measurable shapes such as triangles or circles, and use their respective area formulas to find the total area of the flag.
Is there a standard size for flags that can be used to calculate the area in square inches?
No, there is no standard size for flags. The size of a flag can vary depending on its purpose, design, and country of origin. Therefore, the area of a flag would need to be calculated individually for each flag.
Can the area of a flag change over time?
The area of a flag will remain the same unless it is physically altered or damaged. However, the perceived size of a flag may change over time due to factors such as stretching, fading, or weathering. These changes do not affect the actual area of the flag.
