Solving Integrals with Exponential Functions
  • MHB
  • Thread starter bergausstein
  • Tags
    Bernoulli
In summary, the errors in this summary are:1. Missing the 1/4 factor in the v term.2. Misplacing the 4 in the equation for dy.
bergausstein
191
Solve the ff:
$\displaystyle\frac{dy}{dx}-y=xy^5$
$\displaystyle\frac{dy}{dx}-\frac{y}{x}=-\frac{5}{2}x^2y^3$
can you help start solving these problems? thanks!
These are Bernoulli equations. Such an equation may be written in the form:
\(\displaystyle \frac{dy}{dx}+P(x)y=Q(x)y^n\)
Use of the substitution:
\(\displaystyle v=y^{1-n}\)
will transform the ODE into a linear equation.
the n=5
$\displaystyle v=y^{1-5}=\frac{1}{y^4}$
$\displaystyle y=(\frac{1}{v})^{\frac{1}{4}}$
$\displaystyle y'=-\frac{1}{4}v^{-\frac{5}{4}}\frac{dv}{dx}$
substitute,
$\displaystyle y=(\frac{1}{v})^{\frac{1}{4}}$ and $\displaystyle y'=-\frac{1}{4}v^{-\frac{5}{4}}\frac{dv}{dx}$ to the original D.E
$\displaystyle -\frac{1}{4}v^{-\frac{5}{4}}\frac{dv}{dx}-\frac{1}{v^{\frac{1}{4}}}=x\frac{1}{v^{\frac{5}{4}}}$
multiplying both sides by $v^{\frac{5}{$}}$ and -4.
$\displaystyle \frac{dv}{dx}+4v=-4x$
the integrating factor is $e^{4x}$
$\displaystyle e^{4x}\frac{dv}{dx}+4ve^{4x}=-4xe^{4x}$
$\displaystyle \int D_x(e^{4x}v)=\int -4xe^{4x}$ the rhs using by parts
$\displaystyle e^{4x}v= -e^{4x}+\frac{1}{4}e^{4x}+c$
dividing both sides by $ e^{4x}$
$\displaystyle v= -1+\frac{1}{4}+\frac{c}{e^{4x}}$
now since $v=\frac{1}{y^4}$
$\displaystyle\frac{1}{y^4}=\frac{c}{e^{4x}}-\frac{3}{4}$ --->> this would be my implicit general solution
is my answer correct?
We are given:
\(\displaystyle \frac{dy}{dx}-y=xy^5\)
Use the substitution:
\(\displaystyle v=y^{-4}\implies\frac{dv}{dx}= -4y^{-5}\frac{dy}{dx}\)
Divide the original ODE by$y^5$ observing we are eliminating the trivial solution $y\equiv0$. We obtain:
\(\displaystyle y^{-5}\frac{dy}{dx}-y^{-4}=x\)
Applying the substitution we obtain:
\(\displaystyle \frac{dv}{dx}+4v=-4x\)
Multiply through by $e^{4x}$:
\(\displaystyle e^{4x}\frac{dv}{dx}+4e^{4x}v=-4xe^{4x}\)
This becomes:
\(\displaystyle \frac{d}{dx}\left(e^{4x}v \right)=-4xe^{4x}\)
Integrating (using IBP on the right (which you did incorrectly)), we obtain:
\(\displaystyle e^{4x}v=\frac{1}{4}e^{4x}\left(1-4x \right)+C\)
\(\displaystyle v=\frac{1}{4}\left(1-4x \right)+Ce^{-4x}\)
\(\displaystyle y^{-4}=\frac{1}{4}\left(1-4x \right)+Ce^{-4x}\)
Thus the solution may be given implicitly by:
\(\displaystyle y^4=\frac{4}{1-4x+Ce^{-4x}}\)
Note: the trivial solution we eliminated is not obtainable by the implicit solution gave above.
can you tell me where's my mistake in my solution above?
Edit: There is a small mistake in the integration. Sorry.
[tex]\displaystyle \begin{align*} \int{-4x\,e^{4x}\,dx} = -4x\,e^{4x} + \frac{1}{4}e^{4x} + C \end{align*}[/tex]
$\displaystyle e^{4x}v= -xe^{4x}+\frac{1}{4}e^{4x}+c$
$\displaystyle v= -x+\frac{1}{4}+\frac{c}{e^{4x}}$
my final answer should be$\displaystyle\frac{1}{y^4}=\frac{c}{e^{4x}}-x+\frac{1}{4}$
am I right?
am I right?
Please re-read my last post. You keep missing the factor of -4 on the first term.
$\displaystyle\int -4xe^{4x}dx=-4\int xe^{4x}$
let $u=x$ and $du=dx$
let $dv=e^{4x}dx$ now $v=\frac{1}{4}e^{4x}$
$uv-\int vdu$
$\frac{1}{4}xe^{4x}-\frac{1}{4}\int e^{4x}dx$
$-4\left(\frac{1}{4}xe^{4x}-\frac{1}{4}\frac{1}{4}e^{4x}+c\right)= -xe^{4x}+\frac{1}{4}e^{4x}+c$
isn't correct?
$uv-\int vdu$
isn't correct?
Never mind, what you have is correct. I forgot the 1/4 factor in the v term.
I think this many mistakes means it's time for bed >_<
FAQ: Solving Integrals with Exponential Functions
What is the Bernoulli differential equation?
The Bernoulli differential equation is a type of first-order ordinary differential equation that can be written in the form dy/dx + P(x)y = Q(x)y^n, where n is a constant. It is named after the Swiss mathematician, Jacob Bernoulli.
How do you solve a Bernoulli differential equation?
The Bernoulli differential equation can be solved using the substitution method. By substituting y = u^(1-n), the equation can be transformed into a linear differential equation which can be solved using standard methods such as separation of variables or integrating factors.
What are the applications of solving Bernoulli differential equations?
Bernoulli differential equations have many applications in various fields such as physics, biology, economics, and engineering. They are commonly used in modeling growth and decay processes, population dynamics, and reaction kinetics.
Can all Bernoulli differential equations be solved analytically?
No, not all Bernoulli differential equations can be solved analytically. Some equations may require advanced techniques or cannot be solved in closed form. In such cases, numerical methods or approximation techniques can be used to find an approximate solution.
Are there any real-life examples of Bernoulli differential equations?
Yes, there are many real-life examples of Bernoulli differential equations. One example is the logistic growth model, which describes the growth of a population with limited resources. Another example is the Bernoulli's equation in fluid dynamics, which relates the pressure, velocity, and height of a flowing fluid.
