Solving Integration Help: Heartbeat During Workout
  • MHB
  • Thread starter rachelwind
  • Tags
    Integration
In summary, the conversation discusses a question about pulse rate and heartbeats during a workout, and the need for two applications of integration by parts to solve it. The experts provided a detailed explanation and calculation of the problem.
rachelwind
So here's the question:
If h(t) denotes the number of times a person’s heart beats in t minutes, then the pulse rate p beats per minute is given by p = dh/dt
During a workout an athlete has a pulse rate p(t) beats per minute where
p(t) = 58 + 10.62t^2(e^-0.25t)
t minutes after the start of the workout.
How many times does the athlete’s heart beat during the first 20 minutes of the workout? Give your answer to the nearest complete heartbeat.
Ive been told i need two applications of integration by parts. But i really don't know how to do this. I've managed to do this so far:
Integral (58 dt) + 10.62 Integral ( t^2 e^(-t/4) dt )
58t + 10.62 Integral ( t^2 e^(-t/4) dt )
Let u = t^2. dv = e^(-t/4) dt.
du = 2t dt. v = (-4)e^(-t/4)
Getting the answer:
585 + (10.62)(-4)t^2 e^(-t/4) + (10.62)(8) Integral ( t e^(-t/4) dt )
Let u = t. dv = e^(-t/4) dt
du = dt. v = (-4)e^(-t/4)
Then:
585 + (10.62)(-4)t^2 e^(-t/4) + (10.62)(8)(-4)t e^(-t/4) - (10.62)(8)(-4) (-4)e^(-t/4) + CIs this right so far? Or am i completely off track. Thanks
Hello rachelwind, and welcome to MHB!
Let me first say that I truly appreciate the way you have shown your work and thoughts. This is very helpful to the helpers here in seeing just where you may need guidance. (Yes)
Now, I would agree (although using a slightly different notation), that if we let $H(t)$ be the total number of heartbeats after $t$ minutes, then we need to compute:
\(\displaystyle H(t)=\int_0^t p(x)\,dx\)
\(\displaystyle H(t)=\int_0^t\left(58+10.62x^2e^{-0.25x} \right)\,dx\)
\(\displaystyle H(t)=58\int_0^t\,dx+10.62\int_0^t x^2e^{-\frac{x}{4}}\,dx\)
Getting the simple first integral out of the way...
\(\displaystyle H(t)=58(t-0)+10.62\int_0^t x^2e^{-\frac{x}{4}}\,dx\)
\(\displaystyle H(t)=58t+10.62\int_0^t x^2e^{-\frac{x}{4}}\,dx\)
Now, I am curious how this first term becomes 585? Did you mean to type $58t$ since the "5" and the "t" keys are so close on the keyboard?
Looking at how you set up the integration by parts, you have proceeded correctly by choosing:
\(\displaystyle u=x^2\,\therefore\,du=2x\,dx\)
\(\displaystyle dv=e^{-\frac{x}{4}}\,dx\,\therefore\,v=-4e^{-\frac{x}{4}}\)
And so we have:
\(\displaystyle H(t)=58t+10.62\left(-4\left[x^2e^{-\frac{x}{4}} \right]_0^t+8\int_0^t xe^{-\frac{x}{4}}\,dx \right)\)
\(\displaystyle H(t)=58t+10.62\left(-4t^2e^{-\frac{t}{4}}+8\int_0^t xe^{-\frac{x}{4}}\,dx \right)\)
Now, you have chosen well in your second application of integration by parts in using:
\(\displaystyle u=x\,\therefore\,du=dx\)
And so we have:
\(\displaystyle H(t)=58t+10.62\left(-4t^2e^{-\frac{t}{4}}+8\left(-4\left[xe^{-\frac{x}{4}} \right]_0^t+4\int_0^t e^{-\frac{x}{4}}\,dx \right) \right)\)
\(\displaystyle H(t)=58t+10.62\left(-4t^2e^{-\frac{t}{4}}+8\left(-4te^{-\frac{t}{4}}-16\left[e^{-\frac{x}{4}} \right]_0^t \right) \right)\)
\(\displaystyle H(t)=58t+10.62\left(-4t^2e^{-\frac{t}{4}}+8\left(-4te^{-\frac{t}{4}}-16\left(e^{-\frac{t}{4}}-1 \right) \right) \right)\)
While I used the boundaries of the problem in the limits of integration, we have the same result (differing only by a constant), you would just need to use $H(0)=0$ to find $C$. Your working of the problem is flawless from what I see.
I would go on to clean my result up a bit to write:
\(\displaystyle H(t)=58t-42.48\left(t^2e^{-\frac{t}{4}}+8\left(te^{-\frac{t}{4}}+4\left(e^{-\frac{t}{4}}-1 \right) \right) \right)\)
Now it would just be a matter of evaluating $H(20)$ and rounding to the nearest integer. (Smile)
Hello,
Nice done Mark!
I agree with you but look at your post! That some really well post and guide and especially effort!:) Well used latex cause I always screw somehow when It's a lot to write in latex :)
Hello rachelwind,
Mark has answer your question but I would like to show you how I would solve, it's same as Mark but I do in a difrent way that makes it a lot easy for me cause It's big risk I confused myself when I integrate when you are suposed to integrate two function.
Regards,
Thankyou both. It has become much clearer to me now. (Handshake)
FAQ: Solving Integration Help: Heartbeat During Workout
What is integration in the context of a workout?
Integration in the context of a workout refers to the process of incorporating various exercises and techniques into a single routine in order to achieve a specific fitness goal. This can involve combining different types of exercises, such as cardio and strength training, or using various equipment and tools to target specific muscle groups.
Why is it important to monitor your heartbeat during a workout?
Monitoring your heartbeat during a workout is important because it can give you valuable information about your overall fitness level and the intensity of your workout. By keeping track of your heart rate, you can ensure that you are pushing yourself enough to see results, but not overexerting yourself to the point of potential injury.
How can I measure my heartbeat during a workout?
There are several ways to measure your heartbeat during a workout, including using a fitness tracker or smartwatch, taking your pulse manually, or using a heart rate monitor. These tools can provide real-time feedback on your heart rate and help you stay within your target heart rate zone for optimal results.
What is a target heart rate zone and how do I determine mine?
A target heart rate zone is the range of heartbeats per minute that is most beneficial for achieving your fitness goals. This can vary based on factors such as age, fitness level, and health status. To determine your target heart rate zone, you can use a simple formula: subtract your age from 220, then multiply by a percentage (usually between 50-85%) to find your ideal range.
What should I do if my heartbeat is too high during a workout?
If your heartbeat is too high during a workout, it is important to slow down and take a break. This could be a sign that you are pushing yourself too hard or that you may have an underlying health issue. It is always best to consult with a doctor if you consistently experience a high heart rate during exercise.
