Solving Integration Problem: y^2=\frac{x^2-4}{4}
  • MHB
  • Thread starter bmanmcfly
  • Tags
    Integration
In summary, the conversation is between someone new to a math board and someone returning to university after a 10 year break. The person is struggling with taking the square root of an expression and is unsure if they have to do it for the entire side or for each piece individually. They are asking for clarification on the next step. The expert summarizes that the next step is to take the square root of the entire side and provides the correct equation. The person thanks the expert for the help.
bmanmcfly
45
Hi, I'm new to the board, and newly returning to university after a 10 year hiatus... And for the most part I'm keeping up with the higher level math, but I'm slipping with the simpler stuff...
Without asking for you to solve my math homework for me, I just would like to ask what the next step in this would be:
I have \(\displaystyle y^2=\frac{x^2-4}{4}\)
This is where the 10 years away from a math book is killing me...
If I do the square root, do I have to do the square root of the entire side, or can I do the squares of each piece??
The other option is to have the expression to the power of 1/2... But that creates extra confusion when I do the integral and wind up with a power of 3/2...
How would you handle a situation like this?
Hey Bmanmcfly , welcome :)
I think your question is how to take the square root of :
Then we take it to the whole side :
\(\displaystyle y=\pm\sqrt{\left(\frac{x^2-4}{4}\right)}\)
If that is not clear , can you give me the real question ?
Ya, that's what I thought... I'm minimizing questions asked because this does relate to homework.
Thanks for the nudge in the right direction.
FAQ: Solving Integration Problem: y^2=\frac{x^2-4}{4}
What is the process for solving an integration problem?
The process for solving an integration problem involves finding the antiderivative of the given function. This can be done by using integration techniques such as substitution, integration by parts, or partial fractions. Once the antiderivative is found, the solution can be evaluated by plugging in the limits of integration.
How do you approach an integration problem with a squared term?
For an integration problem with a squared term, such as the given problem y^2=\frac{x^2-4}{4}, you can use the trigonometric substitution method. In this case, you can let x=2secθ and use the trigonometric identities to simplify the function and find the antiderivative.
Is there a way to check if the solution to an integration problem is correct?
Yes, there are a few ways to check the solution to an integration problem. One way is to take the derivative of the solution and see if it matches the original function. Another way is to plug in different values for x and see if they produce the correct y value.
Can you use a calculator to solve an integration problem?
Yes, many calculators have built-in integration functions that can solve integration problems. However, it is important to understand the process and techniques for solving integration problems, rather than relying solely on a calculator.
Are there any tips for solving tricky integration problems?
Some tips for solving tricky integration problems include: identifying if the function can be simplified or manipulated in any way, using integration techniques such as substitution or integration by parts, and being familiar with common antiderivatives. It can also be helpful to break the problem into smaller parts and solve them individually.
