Solving kinematic formula for t
In summary: Thank you @neilparker62 for showing me the completing square method! I was thinking how I would do that!Using constant acceleration equations you have mentioned in post #7 we can find both roots without formula:##d=v_it+\frac 1 2 at^2## ##\rightarrow## ##v_f=v_i+at## ##\rightarrow## ##t=\frac {v_f-v_i}{a}####v_f=±\sqrt {v_i^2+2ad}####t=\frac {±\sqrt {v_i^2+2ad}-v_i}{a}
member 731016
Please see below
Please see below
For ## d = v_it + 0.5at^2##, can we solve for t without using the quadratic formula?
Many thanks!
You can solve a quadratic equation by completing the square.
Likes MatinSAR and member 731016
Oh true, thank you @PeroK !
Which is equivalent to using the formula, no?
Likes member 731016
No. If you forget the formula you can still complete the square. Or, vice versa!
Likes member 731016
The formula is derived by completing the square for the general case of a 2nd degree polynomial. Regardless, completing the square is a technique that is good to know as you will sometimes have to rewrite expressions "in-place", i.e. by subtracting "zero" and what not rather than moving terms from LHS->RHS.
Likes member 731016 and PeroK
Callumnc1 said:
Homework Statement:: Please see below
Relevant Equations:: Please see below
Many thanks!
$${v_f}^2={v_i}^2+2ad$$
$$t=\frac{v_f-v_i}{a}$$
Likes member 731016 and MatinSAR
Again, not really any different from using the formula.
@Callumnc1 , why do you wish to avoid using the formula?
Many thanks!
So, you are asking if you can solve a quadratic equation without using the quadratic formula? Or it is something else?
Likes member 731016
I think it should have same result but the suggested method helps us find roots withhout knowing how to solve a quadratic equation. He finds them using constant acceleration equations ...
Likes member 731016 and SammyS
Thank you for your reply @haruspex !
Thank you for your reply @PeroK!
Thank you for your reply @Mayhem!
Thank you for your reply @neilparker62 !
I was just curious :)
Likes MatinSAR
Thank you for your reply @nasu! Yeah, I guess you think what I'm asking like that!
Thank you for your reply @MatinSAR!
Likes MatinSAR
Completing the square:
$$d=v_it+½ at^2$$ $$\frac{a}{2} \left(t^2 + \frac{2v_it}{a}-\frac{2d}{a}\right) = 0 $$ $$\frac{a}{2} \left[ \left(t+\frac{v_i}{a}\right)^2-\frac{2ad}{a^2} - \left(\frac{v_i}{a}\right)^2\right] = 0 $$ $$t=\frac{\sqrt{{v_i}^2+2ad} - v_i}{a}=\frac{v_f-v_i}{a}$$
Likes member 731016, PeroK and MatinSAR
##t=\frac {±\sqrt {v_i^2+2ad}-v_i}{a}##
Likes neilparker62, member 731016 and PeroK
Thank you @MatinSAR for showing me your method!
Likes MatinSAR
Yes - I should have included the ##\pm##. Then you might call it the kinematics version of the quadratic formula! Good idea to reflect upon when you would use "+" and when "-" in the formula. Also consider the physical meaning of the quadratic's axis of symmetry and its maximum value in the context of projectile motion: $$h(t) = v_it - ½gt^2=\frac{-g}{2} \left[ \left(t-\frac{v_i}{g}\right)^2 - \left(\frac{v_i}{-g}\right)^2\right].$$ Assume up is the positive direction and g is the standard acceleration of gravity: $$g = 9.806 65 ms^{-2} \approx 9.8 ms^{-2}$$.
Sorry, could please explain how you got from ##h(t) = v_it - ½gt^2## to ##h(t) = \frac{-g}{2} \left[ \left(t-\frac{v_i}{g}\right)^2 - \left(\frac{v_i}{-g}\right)^2\right]##?
Many thanks!
Largely the same process as in post #18. I just wrote d as "h(t)" and did not move it onto the right hand side. Otherwise followed standard procedure for completing the square (remove coefficient of t^2 and add/subtract "half the coefficient of t" ^2.)
In Latex, I simply copied the line from post #18 and edited it to remove the term with d in it and replace "a" with "-g" everywhere.
Likes member 731016
neilparker62 said:
Largely the same process as in post #18. I just wrote d as "h(t)" and did not move it onto the right hand side. Otherwise followed standard procedure for completing the square (remove co-efficient of t^2 and add/subtract "half the coefficient of t" ^2.)
Ok thank you very much for your help @neilparker62 !
FAQ: Solving kinematic formula for t
What are the kinematic equations used to solve for time (t)?
The kinematic equations used to solve for time (t) are:1. \( v = u + at \)2. \( s = ut + \frac{1}{2}at^2 \)3. \( v^2 = u^2 + 2as \)4. \( s = \frac{(u + v)}{2}t \)Where:- \( v \) is the final velocity- \( u \) is the initial velocity- \( a \) is the acceleration- \( s \) is the displacement- \( t \) is the time
How do you solve for time (t) using the equation \( v = u + at \)?
To solve for time (t) using the equation \( v = u + at \), rearrange the equation to isolate t:\[ t = \frac{v - u}{a} \]Here, \( v \) is the final velocity, \( u \) is the initial velocity, and \( a \) is the acceleration.
How do you solve for time (t) using the equation \( s = ut + \frac{1}{2}at^2 \)?
To solve for time (t) using the equation \( s = ut + \frac{1}{2}at^2 \), you need to solve the quadratic equation:\[ \frac{1}{2}at^2 + ut - s = 0 \]This can be done using the quadratic formula:\[ t = \frac{-u \pm \sqrt{u^2 + 2as}}{a} \]Choose the positive value of t, as time cannot be negative.
How do you solve for time (t) if the acceleration (a) is zero?
If the acceleration (a) is zero, the kinematic equations simplify. For example, using \( s = ut \):\[ t = \frac{s}{u} \]Here, \( s \) is the displacement and \( u \) is the initial velocity. Since there is no acceleration, the initial velocity remains constant.
How do you solve for time (t) using the equation \( s = \frac{(u + v)}{2}t \)?
To solve for time (t) using the equation \( s = \frac{(u + v)}{2}t \), rearrange the equation to isolate t:\[ t = \frac{2s}{u + v} \]Here, \( s \) is the displacement, \( u \) is the initial velocity, and \( v \) is
