MHB Solving Knapsack Problem: 1st & 2nd Algorithm
  • Thread starter Thread starter mathmari
The discussion revolves around implementing the Knapsack algorithm for a set of elements with given weights and benefits. The first algorithm correctly calculates the maximum benefit of 7 by selecting items (2,3) and (3,4) for a total weight of 5. The second algorithm also confirms similar results but raises questions about how to identify which items to select. Additionally, a fractional version of the Knapsack problem is introduced, but there is confusion regarding the optimal selection of items without exceeding the maximum weight. The overall focus is on understanding the correct application and outcomes of these algorithms.
mathmari
MHB
Hey! :o
I want to apply the Knapsack algorithm at the following:
Code:
n = 4 (# of elements)
W = 5 (max weight)
Elements (weight, benefit):
(2,3), (3,4), (4,5), (5,6)
The first version of the algorithm is the following:
Code:
K(0)=0
for w=1 to W
    K(w)=max_{w_i \leq w} {K(w-w_i)+v_i}
I have found the following:
$$K(1)=\max_{w_i \leq 1} \{K(1-w_i)+v_i\}=0 \\ K(2)=\max_{w_i \leq 2} \{K(2-w_i)+v_i\}=K(2-2)+3=K(0)+3=3 \\ K(3)=\max_{w_i \leq 3} \{K(3-w_i)+v_i \}=\max \{K(3-3)+4, K(3-2)+3\}=\max \{K(0)+4, K(1)+3\}=\max \{4, 3\}=4 \\ K(4)=\max_{w_i \leq 4} \{K(4-w_i)+v_i\}=\max \{K(4-4)+5, K(4-3)+4, K(4-2)+3\}=\max \{K(0)+5, K(1)+4, K(2)+3\}=\max \{5, 4, 6\}=6 \\ K(5)=\max_{w_i \leq 5} \{K(5-w_i)+v_i\}=\max \{K(5-5)+6, K(5-4)+5, K(5-3)+4, K(5-2)+3\}=\max \{K(0)+6, K(1)+5, K(2)+4, K(3)+3\}=\max \{6, 5, 7, 7\}=7$$
At $K(5)=7$, the $7$ came from the elements $(2,3)$ and $(3,4)$. So, the optimal choice is to take these two elements with benefit $3+4=7$. Is this correct?? (Wondering)
The second version of the Knapsack algorithm is the following:
Code:
K(0,j)=0, for all j=1,2, ... ,n
K(w,0)=0, for all w=1,2, ... ,W
for j<-1 to n
     for w<-1 to W
          if w>w_j
             K(w,j)=max{K(w,j-1),K(w-w_j,j-1)+v_j}
          else
             K(w,j)=K(w,j-1)
$$K(1,1)=K(1,0)=0 \\ K(2, 1)=K(2, 0)=0 \\ K(3, 1)=\max \{K(3, 0), K(3-2, 0)+3\}=\max \{0, 0+3\}=\max \{0, 3\}=3 \\ K(4, 1)=\max \{K(4, 0), K(4-2, 0)+3\}=\max \{0, 0+3\}=\max \{0, 3\}=3 \\ K(5, 1)=\max \{K(5, 0)+K(5-2, 0)+3\}=\max \{0, 0+3\}=\max \{0, 3\}=3 \\ \\
K(1, 2)=K(1, 1)=0 \\ K(2, 2)=K(2, 1)=0 \\ K(3, 2)=K(3, 1)=3 \\ K(4, 2)=\max \{K(4, 1), K(4-3, 1)+4\}=\max \{3, 0+4\}=\max \{3, 4\}=4 \\ K(5, 2)=\max \{K(5, 1), K(5-3, 1)+4\}=\max \{3, 0+4\}=\max \{3, 4\}=4 \\ \\
K(1, 3)=K(1, 2)=0 \\ K(2, 3)=K(2, 2)=0 \\ K(3, 3)=K(3, 2)=3 \\ K(4, 3)=K(4, 2)=4 \\ K(5, 3)=\max \{K(5, 2), K(5-4, 2)+5\}=\max \{4, 0+5\}=\max \{4, 5\}=5 \\ \\
K(1, 4)=K(1, 3)=0 \\ K(2, 4)=K(2, 3)=0 \\ K(3, 4)=K(3, 3)=3 \\ K(4, 4)=K(4, 3)=4 \\ K(5, 4)=K(5, 3)=5$$ Is this correct?? (Wondering) How can we find which elements we have to take?? (Wondering)
Technology news on Phys.org
I found the following algorithm for the fractional version of the Knapsack problem:
Code:
    Algorithm fractionalKnapsack(S, W)
    Input: set S of items w/ benefit bi
    and weight wi
    ; max. weight W
    Output: amount xi of each item i
    to maximize benefit with
    weight at most W
    for each item i in S
         xi ← 0
         vi ← bi / wi {value}
    w ← 0 {total weight}
    while w < W
         remove item i with highest vi
         xi ← min{wi , W − w}
         w ← w + min{wi , W − w}
I tried to apply this algorithm and I got the following:
$$x_1 \leftarrow 0 \\ v_1 \leftarrow \frac{3}{2}=1.5 \\ x_2 \leftarrow 0 \\ v_2 \leftarrow \frac{4}{3}=1.33 \\ x_3 \leftarrow 0 \\ v_3 \leftarrow \frac{5}{4}=1.25 \\ x_4 \leftarrow 0 \\ v_4 \leftarrow \frac{6}{5}=1.2 \\ w \leftarrow 0 \\ 0<5 \checkmark \\ \ \ \ \ \ \text{ remove item } =1, \max v_i=1.5 \\ \ \ \ \ \ x_1 \leftarrow \min \{w_1, W-w\}=\min \{2, 5-0\}=\min \{2, 5\}=2 \\ \ \ \ \ \ w \leftarrow 2+\min \{w_1, W-w\}=0+2=2 \\ 2<5 \checkmark \\ \ \ \ \ \ \text{ remove item } i=2, \max v_i=1.33 \\ \ \ \ \ \ x_2 \leftarrow \min \{w_2 , W-w\}=\min \{3, 5-2\}=\min \{3, 3\}=3 \\ \ \ \ \ \ w \leftarrow w+\min \{w_2, W-w\}=2+3=5 \\ 5<5 \times$$ Does this mean that the optimal choice is to take two times the item $1$ and three times the item $2$ ?? (Wondering)
But isn't then the total weight greater than $5$ ?? (Wondering)
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
