Solving Laplace's Equation on a $90^{\circ}$ Wedge
  • MHB
  • Thread starter Dustinsfl
  • Tags
    Laplace
In summary, we want to solve Laplace's equation $\nabla^2u = 0$ on a $90^{\circ}$ wedge of radius $a$ subject to the boundary conditions $u(r,0) = 0$, $u_{\theta}\left(r,\frac{\pi}{2}\right) = 0$, and $u(a,\theta) = f(\theta)$. The standard form of the solutions for $R(r)$ and $\Theta(\theta)$ are $\Theta(\theta) = A\cos\lambda\theta + B\sin\lambda\theta$ and $R(r) = r^{\pm\lambda}$. Using the first boundary condition, we have $A
Dustinsfl
2,281
Solve Laplace's equation $\nabla^2u = 0$ on a $90^{\circ}$ wedge of radius $a$ subject to the boundary conditions
u(r,0) = 0\quad u_{\theta}\left(r,\frac{\pi}{2}\right) = 0\quad u(a,\theta) = f(\theta).
\Theta(\theta) = A\cos\lambda\theta + B\sin\lambda\theta\quad\text{and}\quad
R(r) = r^{\pm\lambda}.
Using the first boundary condition, we have $A = 0$, i.e.
\Theta(\theta) = B\sin\lambda\theta.
Using the second boundary condition, we have
\lambda B\cos\frac{\pi\lambda}{2} = 0.
Therefore, $\lambda = n$ where $n\in\mathbb{Z}$.
The general solution is
u(r,\theta) = \sum_{n = 1}^{\infty}B_nr^{n}\sin n\theta.
With the last condition, we have
u(a,\theta) = \sum_{n = 1}^{\infty}B_na^{n}\sin n\theta = f(\theta)
where the Fourier coefficients are $B_n = \frac{1}{a^n\pi}\int_{-\pi}^{\pi}f(\theta)\sin n\theta d\theta$.
Then the general solution with the defined conditions is $u(r,\theta) = \sum\limits_{n = 1}^{\infty}B_nr^{n}\sin n\theta$ where $B_n$ is defined as above.
Let's take the case where $f(\theta) = \theta$.
\begin{alignat*}{3}
B_n & = & \frac{1}{a^n\pi}\int_{-\pi}^{\pi}f(\theta)\sin n\theta d\theta\\
& = & \frac{1}{a^n\pi}\left[\left.-\frac{\theta\cos n\theta}{n}\right|_{-\pi}^{\pi} + \left.\frac{\sin n\theta}{n^2}\right|_{-\pi}^{\pi}\right]\\
& = & \frac{2(-1)^{n + 1}}{a^nn}
\end{alignat*}
The solution to this Laplace equation when $f(\theta) = \theta$ is
u(r,\theta) = 2\sum\limits_{n = 1}^{\infty}\frac{(-1)^{n + 1}r^{n}}{a^nn}\sin n\theta.
This is incorrect. The cosine function becomes zero only when \(\lambda\) takes odd values. That is, \(\lambda=2n+1\) where \(n\in\mathbb{Z}\).
So after I made the correction, I ended up with
u(r,\theta) = 2\sum\limits_{n = 1}^{\infty}\frac{r^{n}}{a^{2n - 1}(2n - 1)}\sin (2n - 1)\theta.
FAQ: Solving Laplace's Equation on a $90^{\circ}$ Wedge
How do you solve Laplace's Equation on a $90^{\circ}$ Wedge?
To solve Laplace's Equation on a $90^{\circ}$ Wedge, you can use the separation of variables method. This involves separating the dependent variables and solving the resulting ordinary differential equations for each variable.
What are the boundary conditions for solving Laplace's Equation on a $90^{\circ}$ Wedge?
The boundary conditions for solving Laplace's Equation on a $90^{\circ}$ Wedge depend on the specific problem. However, in general, the boundary conditions include specifying the values of the dependent variables at the boundaries of the wedge.
What are some applications of solving Laplace's Equation on a $90^{\circ}$ Wedge?
Solving Laplace's Equation on a $90^{\circ}$ Wedge has various applications in engineering and physics. One common application is in the study of the flow of fluids around a wedge-shaped object, such as an airplane wing or a ship's hull.
Can Laplace's Equation on a $90^{\circ}$ Wedge be solved analytically?
Yes, Laplace's Equation on a $90^{\circ}$ Wedge can be solved analytically using the separation of variables method. However, in some cases, it may be necessary to use numerical methods to obtain a solution.
Are there any limitations to solving Laplace's Equation on a $90^{\circ}$ Wedge?
One limitation of solving Laplace's Equation on a $90^{\circ}$ Wedge is that it assumes the wedge is perfectly smooth and has no imperfections. In real-world situations, there may be irregularities or imperfections on the surface of the wedge, which can affect the accuracy of the solution.
