Solving Law of Mass Action Problem with X', Y', and Z
  • MHB
  • Thread starter Carla1985
  • Tags
    Law Mass
In summary: My supervisor explained it to me that if I have a reaction, $Y+aZ\rightarrow bZ$ then the differential equation for $Z$ is proportional to $(b-a)YZ$, so if $a=b$ the difference is $0$ so the coefficient is $0$, i.e. there is no change in the concentration of $Z$.But if that is the case, where did X go? (Wondering)We don't know.In summary, Carla is working through some questions in a book and has got stuck on one. The question is:"The equations below come from applying the law of mass action to two reactions.
Carla1985
94
I am working through some questions in a book and have got stuck on one. The question is:
$$X'=aXY \\
Y'=bYZ+cZ \\
Z'=dYZ+eZ$$
Find the two reactions and determine how the coefficients a,b,c,d and e are related, if at all. Assume a,b,c,d,e are nonzero but can be positive or negative."
I have got the first reaction as $X+Y\overset{a}\rightarrow Y$ with being negative. For the second reaction I initially tried $Y+Z\rightleftarrows Z$ which would work for $Y'$ but doesn't for $Z'$.
Could someone please point me in the direction of how I can work out what this second reaction needs to be.
Thanks
Carla
Mathematics news on Phys.org
$$X'=aXY \\
Y'=bYZ+cZ \\
Z'=dYZ+eZ$$
Thanks
Carla
Hey Carla! ;)
It seems to me that it works for Z' as well.
Why do you think that it doesn't? (Wondering)
I like Serena said:
Hey Carla! ;)
That was my understanding. Have I misunderstood somewhere along the way?
I see a couple of differences.
The reaction is in 2 directions instead of 1.
And it is not given that a=b, so we should assume they are different. (Thinking)
Sorry, I'm a little confused. If I have the reaction I originally thought $Y+Z\leftrightarrows Z$ isn't $Z'$ just $0$ as there is a $Z$ on either side of the reaction so the amount of $Z$ doesn't change with the reaction?
We don't know.
We can only assume that Z decreases proportionally to YZ, and simultaneously increases due to the right hand side.
And then Z decreases proportionally to Z, and simultaneously increases due to the left hand side.
To model this, I think we should say that $Z'=dYZ+eZ$, which fits the equations.
This is a bit odd actually.
We are assuming that the concentration of Y on the left side decreases with the same amount that it increases on the right side, so that effectively there is no change in Y.
It seems to contradict conservation of mass.
FAQ: Solving Law of Mass Action Problem with X', Y', and Z
What is the Law of Mass Action?
The Law of Mass Action is a mathematical principle that describes the relationship between the concentration of reactants and the rate of a chemical reaction. It states that the rate of a chemical reaction is directly proportional to the product of the concentrations of the reactants.
How do X', Y', and Z affect the Law of Mass Action?
X', Y', and Z are known as rate constants and they represent the specific reaction rates for the individual reactants. These constants are used in the Law of Mass Action to calculate the overall rate of the reaction based on the concentrations of the reactants.
Can the Law of Mass Action be applied to all chemical reactions?
No, the Law of Mass Action is specifically applicable to reversible reactions where the reactants and products are in equilibrium. It does not apply to irreversible reactions or reactions that are not in equilibrium.
How can the Law of Mass Action be used to solve problems?
The Law of Mass Action can be used to determine the equilibrium concentrations of reactants and products in a chemical reaction. By using the concentrations and rate constants, the equilibrium constant (K) can be calculated, which can then be used to solve for unknown concentrations or determine the direction of the reaction.
Are there any limitations to using the Law of Mass Action?
Yes, the Law of Mass Action assumes ideal conditions and does not account for factors such as temperature, pressure, or catalysts that may affect the rate of a reaction. It also assumes that the reaction is taking place in a closed system and that concentrations remain constant throughout the reaction.
