Solving Linear Equations d= Lh/R1+R2 for L
In summary, d=Lh/R1+R2 is solved when R1 and R2 are set equal to 10. L is also solved when R1 and R2 are set equal to h.
Rose Bernard
How do i solve d= Lh/R1+R2.
How do i also solve d= LM/R2+R1.
Mathematics news on Phys.org
Hello, and welcome to MHB! (Wave)
Let me first ask if the equations are:
1.) \(\displaystyle d=\frac{Lh}{R_1+R_2}\)
2.) \(\displaystyle d=\frac{LM}{R_1+R_2}\)
If so, which variable are you being asked to solve for in each equation?
Solve for L:
d=Lh/R1+R2
Also solve d= LM/R2+R1.
- - - Updated - - -
They are two different questions.
Yes, I made my best attempt to decide what your somewhat ambiguous notation means...I posted both equations, and I am waiting for you to confirm whether I have interpreted them correctly and for which variable each are to solved. (Smile)
Yes,those are the equations.
Are you there?
Are you there?
Yes...this isn't like instant messaging. Sometimes a reply might take more than a few minutes, as I am also doing many other things. :)
So, the first equation is:
And we are to solve for $L$.
The first thing I would do is multiply both sides by $R_1+R_2$ to clear the denominator on the RHS. What do we get in doing so?
Again this are the questions:
Solve for L: d=Lh/R1+R2. This is the first question.
Second question:
d= LM/R2+R1.
Thank you.
- - - Updated - - -
I really don't know how to solve it,so please just help me out. Help me by solving and telling me the answer,and i will learn it.
I am offering guidance, so that you are involved in the process of solving...you'll learn more that way. So, if we multiply as I suggested, we get:
\(\displaystyle d\left(R_1+R_2\right)=\frac{Lh}{R_1+R_2}\left(R_1+R_2\right)\)
What do you have when you cancel or divide out common factors on the RHS?
Please no idea.
Tell me
Rose Bernard said:
Please no idea.
Tell me
C'mon. \(\displaystyle \frac{a}{a} = 1\) for all \(\displaystyle a \neq 0\).
So what is \(\displaystyle \frac{R_1 + R_2}{R_1 + R_2}\)?
-Dan
-Dan
R1+R2=R3.
If am not mistaking.
- - - Updated - - -
-Dan
Are you there
Rose Bernard said:
R1+R2=R3.
Let's try again with numbers. Set \(\displaystyle R_1 + R_2 = R_3 = 10\). Then
\(\displaystyle \frac{R_1 + R_2}{R_1 + R_2} = \frac{R_3}{R_3} = \frac{10}{10} = \)?
-Dan
-Dan
Please i don't know
- - - Updated - - -
Rose Bernard said:
Please i don't know
Maybe R3/R3
Hello
Please we didn't complete our business yesterday.
- - - Updated - - -
Please help me solve: d= LM/R2+R1.
And also help me solve: solve for L: d=Lh/R1+R2.
- - - Updated - - -
Hello MarkFL
Please we didn't finish our business yesterday.
If you don't mind can we continue?
Rose Bernard said:
Hello
I left it at:
Cancelling on the RHS leaves:
\(\displaystyle d\left(R_1+R_2\right)=\frac{Lh}{\cancel{R_1+R_2}}\left(\cancel{R_1+R_2}\right)\)
\(\displaystyle d\left(R_1+R_2\right)=Lh\)
Now, since $L$ is being multipled by $h$, we want to divide both sides by $h$...what do we get?
Rose, are you a student attending math classes?
FAQ: Solving Linear Equations d= Lh/R1+R2 for L
What is the formula for solving linear equations?
The formula for solving linear equations is d = Lh/R1 + R2, where d represents the dependent variable, L represents the independent variable, h represents the coefficient, and R1 and R2 represent the constants.
How do you isolate the variable in a linear equation?
To isolate the variable in a linear equation, you need to use the inverse operation on both sides of the equation. In this case, you would first subtract R2 and then divide both sides by h. This will leave you with the simplified equation L = (d - R2) * (R1/h).
What are the steps for solving linear equations?
The steps for solving linear equations are as follows:
  1. Collect all like terms on one side of the equation.
  2. Use inverse operations to isolate the variable on one side.
  3. Check your solution by substituting it back into the original equation.
What is the purpose of solving linear equations?
The purpose of solving linear equations is to find the value of the independent variable (in this case, L) that will make the equation true. This can be used to solve real-life problems and make predictions.
Can linear equations have more than one solution?
Yes, linear equations can have more than one solution. In this case, the equation d = Lh/R1 + R2 has an infinite number of solutions, as there are many different combinations of values for L, h, R1, and R2 that will make the equation true.
