Python Solving Linear Programming problems in python PulP
The discussion focuses on formulating a linear programming problem in Python using the PuLP library, specifically addressing the objective function and constraints related to supply and demand. The user is uncertain about the concept of dummy demand and how to allocate the excess supply of 33,500, which arises from an imbalance between total supply and demand. Guidance is provided on simplifying the problem by eliminating certain variables through derived equations, allowing for a more manageable four-variable model instead of eight. The importance of adjusting constraints to equalities for demand fulfillment is emphasized, alongside the need to maintain a balance between producer and consumer variables. Ultimately, the goal is to create a streamlined linear programming model that can be effectively solved using PuLP.
alpha
Okay so far I have come up with the following:
The objective function is:
30LADA + 40LAHO + 50SADA + 40SAHO + 110DANY + 125DACH + 105HONY + 115HOCH (to read this please see the table above as I have just used the first two letters of each except NY which I have represented by NY). In these I have also added in the additional cost of $90 from Houston and $70 from Houston. Since that should be covered in the cost matrix (I think?)
My constraints are:
1. all variables must be >= 0
2. SADA + SAHO <= 55,500
3. LADA + LAHO <= 50000
4. DACH + HOCH <= 27000
5. DANY + HONY <= 45000
6. LADA + SADA - DANY - DACH = 0
7. LAHO + SAHO - HONY - HOCH = 0
Now what I don't understand is constraints 6 and 7. I have gone over a few books that talk about dummy demand since this is clearly not a balanced question (demand = 72000, supply = 105500) with the difference being 33500. So I noticed in similar questions people using dummy demand. Would appreciate some help in explaining what dummy demand is and how I would allocate the 33500 since I am not entirely sure how to split it.
From there I get the following table:
DallasHoustonNYChicagoDummySupply
LA
30​
40​
0​
50000​
SD
50​
40​
0​
55500​
Dallas
110​
125​
0​
Houston
105​
115​
0​
Demand
45000​
27000​
33500​
Now I know my dummy demand column is wrong but I am not too sure about the rest either. Can someone please give me some guidance on this? I am yet to export this to PuLp on python and solve it since I have to formulate the table first. Thank you!
Technology news on Phys.org
I don't know about dummy demand but it seems to me you can simplify the problem to have fewer variables. I think of constraints as being inequalities like items 1-5 whereas equations ('equalities') like 6-7 allow us to just remove variables from the calc and thus simplify it.
Before proceeding, note that, since you are required to meet demand, you should replace the <= sign in 4 and 5 by an = sign.
Hence we have eight unknown variables and four equations 4-7, which allows us to eliminate four variables, expressing them in terms of the remaining four variables.
We need to exercise judgement in which variables to eliminate. For instance we can't eliminate the four refiners to consumer variables, since that leaves only three variables, since the four producer-to-refinery variables must add to 27000+45000. We need to leave uneliminated at least one producer-to-refinery and oner refinery-to-consumer variable.
So let's eliminate one producer-to-refiner variable (say SADA) and three refiner-to-consumer variables (say all except HONY).
That will leave us with four unknown variables saho, lada, laho and hony
You get the other four variables by the derived equations:
1. dany = 45k - hony
2. sada = (45k + 27k) - (saho + lada + laho)
3. dach = lada + sada - (45k - hony)
4. hoch = 27k - dach
Substitute those in your objective function to get a function that only uses the four unknown variables
You have ten inequalities, being the requirement that each of the eight variables be >= 0, and the two producer inequalities (limits of 55.5k for San Diego and 50k for LA). Where eliminated variables occur in those inequalities, substitute for them using the above to obtain inequalities in terms of the four unknown variables.
So now you have a much simpler 4-variable LP problem instead of an 8-variable one.
Principle: use all available equations to reduce the number of variables, before you start linear programming.
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
