MHB Solving Linear Transformations w/ Bases of Vector Spaces
The discussion revolves around proving that the set {f1, f2, f3} forms a basis for the vector space V, given that {e1, e2, e3} is a basis. It is established that {f1, f2, f3} is linearly independent and spans V, confirming it as a basis. Additionally, the conversation addresses finding the matrix representation of the linear transformation T with respect to the basis {e1, e2, e3}, given its representation in the basis {f1, f2, f3}. Various methods, including the change-of-basis matrix and direct computation, are discussed to derive the correct transformation matrix. The participants clarify misunderstandings regarding coordinate transformations between the bases.
Chris L T521
MHB
Here is the question:
george said:
Let $\{e_1, e_2, e_3\}$ be a basis for the vector space $V$ and $T: V \rightarrow V$ a linear transformation.
(a)
Show that if $f_1=e_1+e_2+e_3$, $f_2=e_1+e_2$, $f_3=e_1$ then $\{f_1,f_2,f_3\}$ is also a basis for $V$
(b)
Find the matrix $B$ of the $T$ with respect to the basis $\{e_1,e_2,e_3\}$ given that its matrix with respect to $\{f_1,f_2,f_3\}$ is
\[A = \begin{pmatrix}0 & 0 & 1\\ 0 & 1 & 1 \\ 1 & 1 & 1\end{pmatrix}\]
Here is a link to the question:
Let {e1, e2, e3} be a basis for the vector space V and T: V -> V a linear transformation.? - Yahoo! Answers
I have posted a link there to this topic so the OP can find my response.
Mathematics news on Phys.org
Hello george,
Since $\{e_1,e_2,e_3\}$ forms a basis for $V$, we see that they're linearly independent, i.e. for scalars $c_1,c_2,c_3\in\mathbb{R}$ (or any field of interest) $c_1e_1+c_2e_2+c_3e_3 = 0 \iff c_1=c_2=c_3=0$. Now, let $d_1,d_2,d_3\in\mathbb{R}$. We now consider the equation $d_1f_1+d_2f_2+d_3f_3 = 0$. Since $f_1=e_1+e_2+e_3$, $f_2=e_1+e_2$ and $f_3=e_1$, we see that
\[\begin{aligned} d_1f_1+d_2f_2+d_3f_3 = 0 &\implies d_1(e_1+e_2+e_3) + d_2(e_1+e_2) + d_3(e_3) = 0 \\ & \implies (d_1+d_2+d_3)e_1 + (d_1+d_2)e_2 + d_1e_3 = 0\end{aligned}\]
Since $\{e_1,e_2,e_3\}$ was a basis, we must now have that
\[\left\{\begin{aligned} d_1 + d_2 + d_3 &= 0\\ d_1 + d_2 &= 0 \\ d_1 &= 0\end{aligned}\right.\]
which clearly has the solution $d_1=d_2=d_3=0$. Therefore, $d_1f_1 + d_2f_2 + d_3f_3 = 0 \iff d_1=d_2=d_3=0$ and hence $\{f_1,f_2,f_3\}$ is a linearly independent set in $V$. Furthermore, $\mathrm{Span}\{f_1,f_2,f_3\} = \mathrm{Span}\{e_1,e_2,e_3\} = V$; hence, $\{f_1,f_2,f_3\}$ is also a basis for $V$.Next, we're told that in terms of the basis $\{f_1,f_2,f_3\}$, the linear transformation $T:V\rightarrow V$ is represented by the matrix
\[A = \begin{pmatrix}T(f_1) & T(f_2) & T(f_3)\end{pmatrix} = \begin{pmatrix}0 & 0 & 1\\ 0 & 1 & 1 \\ 1 & 1 & 1\end{pmatrix}\]
Since $f_1 = e_1 + e_2 + e_3$, $f_2 = e_1 + e_2$, and $f_3 = e_1$, we see that
\[T(f_1) = T(e_1) + T(e_2) + T(e_3),\quad T(f_2) = T(e_1) + T(e_2),\quad\text{and}\quad T(f_3) = T(e_1).\]
Comparing the columns of these two matrices, we have the system of equations
\[\left\{\begin{aligned}T(e_1) + T(e_2) + T(e_3) &= { \begin{pmatrix}0\\ 0 \\ 1\end{pmatrix}} \\ T(e_1) + T(e_2) &= {\begin{pmatrix} 0 \\ 1 \\ 1\end{pmatrix}} \\ T(e_1) &= {\begin{pmatrix}1 \\ 1 \\ 1\end{pmatrix} }\end{aligned}\right.\]
Solving this system yields that
\[T(e_1) = \begin{pmatrix}1\\ 1\\ 1\end{pmatrix},\quad T(e_2) = \begin{pmatrix}-1\\ 0 \\ 0\end{pmatrix},\quad\text{and}\quad T(e_3) = \begin{pmatrix}0 \\ -1 \\ 0\end{pmatrix}\]
Therefore, in terms of the basis $\{e_1,e_2,e_3\}$, the linear transformation $T:V\rightarrow V$ is represented by the matrix
\[B = \begin{pmatrix} T(e_1) & T(e_2) & T(e_3)\end{pmatrix} = \begin{pmatrix}1 & -1 & 0\\ 1 & 0 & -1\\ 1 & 0 & 0\end{pmatrix}\]I hope this makes sense!
An alternativ way for a) is to check that that $$det \neq 0$$ but the way Chris L T521 is probably the best!
Basicly what I did Was put $$f_1,f_2,f_3$$ as a columne to a matrice and Then calculate the determinant! (You can se in picture which is $$f_1,f_2,f_3$$
Regards,
$$|\pi\rangle$$
Alternative 3:
Because the set $\{f_1,f_2,f_3\}$ has 3 elements it suffices to show that this set spans $V$ (since $V$ has dimension 3 because of the size of the given basis).
We have:
$e_1 = f_3$
$e_2 = f_2 - f_3$
$e_3 = f_1 - f_2$
so $c_1e_1 + c_2e_2 + c_3e_3 = c_1(f_3) + c_2(f_2 - f_3) + c_3(f_1 - f_2)$
$= c_3f_1 + (c_2 - c_3)f_2 + (c_1 - c_2)f_3 \in \text{span}(\{f_1,f_2,f_3\})$.
Before tackling the second question, it bears looking into what the change-of-basis matrix $P$ is:
$P = \begin{bmatrix}0&0&1\\0&1&-1\\1&-1&0 \end{bmatrix}$
If we call our bases B (for the $e$'s) and C (for the $f$'s), then:
$P([\mathbf{v}]_B) = [\mathbf{v}]_C$
The problem gives us $P^{-1}$ straight off the bat, it is:
$P^{-1} = \begin{bmatrix}1&1&1\\1&1&0\\1&0&0 \end{bmatrix}$
So the matrix we desire is:
$A' = P^{-1}AP$, which sends:
$[\mathbf{v}]_B \to [\mathbf{v}]_C \to [T(\mathbf{v})]_C \to [T(\mathbf{v})]_B$
Computing, we have:
$A' = P^{-1}AP = \begin{bmatrix}1&1&1\\1&1&0\\1&0&0 \end{bmatrix} \begin{bmatrix}0&0&1\\0&1&1\\1&1&1 \end{bmatrix} \begin{bmatrix}0&0&1\\0&1&-1\\1&-1&0 \end{bmatrix}$
$ = \begin{bmatrix}1&2&3\\0&1&2\\0&0&1 \end{bmatrix} \begin{bmatrix}0&0&1\\0&1&-1\\1&-1&0 \end{bmatrix}$
$ = \begin{bmatrix}3&-1&-1\\2&-1&-1\\1&-1&0 \end{bmatrix}$
Huh. I get a different matrix. One of us must be wrong, who is it?
Chris L T521 writes:
$T(f_3) = T(e_1) = \begin{pmatrix}1\\1\\1 \end{pmatrix}$
This is misleading...coordinates don't tell us which vector we have UNTIL we choose a basis. What we actually have is:
$T(e_1) = T(f_3) = f_1 + f_2 + f_3 = (e_1 + e_2 + e_3) + (e_1 + e_2) + e_3 = 3e_1 + 2e_2 + e_3$.
We should expect that in the B-basis, $A'$ should map (1,0,0) to (3,2,1). I think I am correct.
EDIT:
Chris L T521, the mistake you made is that your images for $T(e_j)$ are still in the C-basis, you need to convert these back to the B-basis.
Deveno said:
Alternative 3:
We have:
$e_1 = f_3$
$e_2 = f_2 - f_3$
$e_3 = f_1 - f_2$
Computing, we have:
EDIT:
Ah, after posting my answer, I had a slight feeling something was off with the matrix I came up with. Thanks a bunch for clarifying that!
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
