Solving Math Problem: Why is m=2, not 1?
  • Thread starter Thread starter hidemi
The discussion centers on the confusion regarding the value of m in a math problem involving wave interference. The original calculation using m=1 yields incorrect results, while substituting m=2 leads to a correct answer of θ=29. However, further clarification reveals that the correct application of the formula with m=2 actually results in θ=0.57º, indicating an arithmetic error in the calculations. Additionally, the correct distance d should be 0.3*10^-9 m instead of 3*10^-9 m. The participant acknowledges the mistake and seeks further assistance.
hidemi
An x-ray beam of wavelength 3 x~ 10^−11 m is incident on a calcite crystal of lattice spacing 0.3 nm. The smallest angle between crystal planes and the x-ray beam which will result in constructive interference is:
A. 2.9◦
B. 5.7◦
C. 12◦
D. 23◦
E. none of these
The answer is A
2 d sinθ = m λ
2x0.3x10^-9 sinθ = 2.3 x 10^-11
However, why is the m=2 ?
2 d sinθ = m λ
I calculate by :
2 *3*10^−9* sinθ = 1 * 3 *10^−11
but can not get a correct answer.
If I substitute the m by 2:
2 *3 *10^−9 * sinθ = 2* 3 * 10^−11
then the answer : θ=29 is correct
I wonder why the m is 2 not 1. Could someone help me?
hidemi said:
I calculate by :
You have used d = 3*10^-9m instead of d = 0.3*10^-9 m.
And (when using m=2) your equation "2 *3 *10^−9 * sinθ = 2* 3 * 10^−11" gives θ = 0.57º, not "θ=29". So you are making some arithmetic error as well (incorrect use of brackets on calculator?).
With m=1:
mλ/(2d) = 1 * 3*10⁻¹¹ / (2 * 0.3*10⁻⁹) = 0.05
θ = sin⁻¹(mλ/(2d)) = sin⁻¹(0.05) = 2.9º (Answer A).
With m=1:
Thanks for pointing out my mistake.
