Solving Motion Equations with Integration
The discussion focuses on solving motion equations through integration, specifically addressing confusion around setting components to zero. The initial attempt to derive position using integration led to unreasonable time values when incorrectly setting the j-component to zero. Clarification was provided that the y=0 corresponds to the x-axis, not the y-axis. After correcting the approach and applying the quadratic formula to the x-component, the participant successfully found a solution. The conversation highlights the importance of accurately interpreting the components in motion equations.
runningphysics
A particle leaves the origin with its initial velocity given by v⃗ 0=14i+13jm/s, undergoing constant acceleration a⃗ =−1.3i+0.26j m/s2. Find when and where the particle crosses the y axis.
Δx=V_0 t+1/2 at^2
and other kinematics equations
I'm not sure where to start, when I tired using integration of the initial equation to get pos(t)=-.65t^2 i + .13t^2 j + 14ti +13tj but after separating each component, i and j, and setting j equal to zero I got 0 or -100 seconds which doesn't seem like a reasonable answer.
First, you do not set j = 0. I assume you mean setting the j-component to zero.
Second, y=0 is the x-axis, not the y-axis. The y-axis corresponds to x=0.
OK, I tried it out and it works! I was confused with the wording of the question, but setting the x equation, x=-.65t^2 i + 14t i, equal to zero and using the quadratic worked. Thanks for your help!
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
